What did you do to your Lotus today...
Painted a handful of brackets, and put it under the cover.
Then spent a few hours with some pals refitting the engine and gearbox to a Lotus Sunbeam that one of them is restoring,
- persiflage
Drove it; washed it; clay barred it; polished it; waxed it.
'72 Sprint
'72 Sprint
- richardcox_lotus
Sent two five speed boxes to Norfolk ......
Replaced the Powerspark module with points today. The module failed on the way to the Oulton Park Gold Cup, left me stranded for four hours at the roadside till the RAC arrived with a low loader truck. So annoyed the module lasted 1500 miles, I'll stick with the points now.
- Elseezed
Maybe both, I’ll ask my better half....
Wait...winter? What calendar are you using?
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Only just got mine back on the road so out enjoying it even at reduced running in rpm. Pity I missed the quiet lockdown roads.
so far: Carb fiddling, had to twist 3/4 shaft slightly to synch, may need to recheck float levels & hoping the webcon pump really didn't need a reg as well... handbrake adjustment & temp mod to add another return spring ( new tree required over winter....) and a slight can cover oil leak new gasket in stock for when I drop the oil and check the clearances.
More chance of it getting a coating of actual clay rather than me using a claybar
Don't see me parking mine up just yet as enjoying it but each to their own although it hasn't even seen the wet yet the devil in me is waiting for a touch of snow
- Sploder90
