Posted: Tue Jun 30, 2020 12:36 am
Very nice! Whose 'small spring' kit is that?
https://lotuselan.net/forums/
74Twincam wrote:Just about wrapped up with Phase 1 of the full refresh- all suspension and bits back onto the frame finally. I have to fit up the rear hubs and then wheels go on! It'll obviously need all the adjustments for steering, brakes and suspension once it's all back together and properly weighted, but this feels good to be this far.
Next up, the engine!
Thanks to everyone here for all the great posts and answers to questions as I've gone, this forum has been a great help to the project.
Andy8421 wrote:If the pedal is spongy, that is going to be air somewhere.
If there is a 'long pedal' which goes a long way before it is firm - and is shorter on the second pump, then you probably have something knocking the pads back. The first push gets the pads back in contact with the disc. Most likely cause is runout in the discs.
If you have a servo, it can sometime exhibit similar symptoms - but if you have just changed the discs, that would be my first area to check.
Good luck.
