Posted: Sun May 17, 2020 5:40 pm
EPC 394J wrote:MazziniI have a couple of small niggles, the TTR steering column joint is huge and the top nut and bolt rub on the bottom rad hose.
I had the same. Check and/or adjust the position of your steering rack. (Then re-adjust your tracking if necessary)
Thanks for that. I'm not sure how much rotation their is on an Elan rack, but will take a look.
Last year I was trying to fit a steering column UJ to a Mk 14 Elite, I just couldn't understand how the column and rack were meant to line up, then the penny dropped and I undid the rack bolts rotated the rack till it lined up with the column and fitted the UJ.
