What did you do to your Lotus today...
Panda wrote:In our case, a noisy Sunday running the 26R replica at Wakefield Park near Goulburn in NSW Australia. Driver Len Goodwin almost got a pb doing 1.08.4 and came 11th outright in a field of about 100 cars at the Combined Sports Car Association Supersprints despite a damp track. Lots of fun and great company!
Alan P.
Nice time wish I could do that at Wakefield
I took the both damaged and new 26R shell and new rolling chassis out to have roll cage and seat fitted, footwell extended, carbon/kevlar reinforcements to drivers floor, boot under fuel tank and inside tunnel area adjacent to flywheel etc, finally have some money aside to progress the rebuild.
V
V
- vstibbard
a long awaited job completed yesterday : give a tad more room to the right foot for my street elan, so that it does not need to be driven with tigth race shoes...
tightened accelarator nut to get the slack away (that was the easy part)
bent the brake and clutch pedals 8mm to the left (pedal box off required, a typical Lotus sunday evening job)
next I will consider a foot rest...
____
a couple days later, here is the foot rest
the box is made of a sheet of 1.5mm alloy sheet, attached to the lattice and with a fold wedged behind the card : about 20mm side rest for the left foot... not much more room down there to fit a wider one.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
A Sunday evening job ???
It took me ages to do that, especially getting the bearing block back in the correct place so that it wasn`t binding. A friend left the block in place and saved all the trouble I made myself.
It was one of the best modifications I have done and I would highly recommend it.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
ericbushby wrote:A Sunday evening job ???
Eric in Burnley
1967 S3SE DHC
well, night comes early now... I would say around 5 to 10PM with a couple things in between now and then to get my nerves back. I did not remove the wheel side pivot point either, only the handbrake ... and stock voltage regulator since the 2 small bolts are hidden behind it on the firewall (typical Lotus job for long harmed sticky fingered mechanics).
What took me the longest was to muster the motivation to do it, several years... and eventually what triggered it was that I had to remove the tandem master cylinder to solve for good (hopefully) the reservoir front port leak. I now have a bruised rib from lying on the rocker panel but was quite happy at the end of it, eventually.
S4SE 36/8198
The differential was leaking from the front seal of my recently acquired 1965 Elan S2. Chris & Ted came over to help me remove the diff, replace the seal and re-install. Took two hours to remove and less to install. Good work in a day. Great to have such good Elan friends!
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
I?m very lucky to have a number of friends that are mechanically inclined and like to work on Lotus cars. Plus I offer free beer and lunch if your helping
Glen
