What did you do to your Lotus today...
661 wrote:Welded in the seat mounting brackets
Cut some holes
Starting to look like a car
nice !
I still have a hard time to make up my mind about the full version cage vs. a lighter one tough... esp. since my period body (...) is not going to be light.
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Today we fettled the body on the 26R to make the light pods fit. We also fitted the original badge.
Best regards, P
Best regards, P
Peter James Evans
1965 Elan S2 (Early 26R replica)
2001 Citroen Saxo Hill Climb Car
2004 Mini R52
2004 Mini R52
- Elan Peter
Elan Peter wrote:Today we fettled the body on the 26R to make the light pods fit. We also fitted the original badge.
Best regards, P
Hi Peter
Love the rebuild its looking great i always love to see a well developed Elan
You really should refer to your build consistently as a "26R replica" not as a "26R". There is at tendency for "rebuilds" to turn into "26R replicas" and then into "26R" and then into "Genuine 26R" as the car passes through the years and multiple owners. This why there are at least 3 times as many genuine 26R's out there than Lotus originally built
I am very sorry if I caused any confusion. I used inverted commas to symbolise it's replica-ness. It is however a genuine s2 and was bought by us from Peter Shaw (Elan racing driver) shortly after he died. I do not want anybody to think I am trying to pass the car off as a genuine 26R and I know that most people call them a GTS but this car will be identical in every way to an original early 26R including an original interior that we have replicated!
I hope that's cleared it up. I will refer to the car as the Elan from now on.
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
I guess having light pods rather than faired-in fixed lights would be a bit of a dead giveaway to the untrained eye (like mine)? Whatever, I'm sure it'll look fine however you care to describe it. I think what you call it only really matters if you are attempting to sell it as a "26R" (which would be a bit naughty, not that I am suggesting you're guilty of this!)
JonB - Coveted Fifth Gear
Yes, all of the the first 50 or so had pop-ups rather than fixed ones.
And don't worry, by the way, I never want to sell it . I love it much more than the s3 we had and that one wasn't in bits!
Best regards, P
Best regards, P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
Been getting her ready to drive her out of "towing home" distance. I've owned this car since 2015, and this is the first time I'm going to drive it more than 20-30 miles from home. We're heading to an all-British car show in Carthage, Missouri, about 150 miles from Tulsa, OK.
The first 4 years of ownership were devoted to getting the power train sorted. Now that that's done, I've spent the last couple of weeks working on weather-proofing the car. Including:
- Installing the snaps that the top requires at the top/outside of the windshield posts. First I had to stuff epoxied toothpicks into the holes that were where the snaps were supposed to be.
- Removing the snaps that the PO had put at the top/inside of the windshield posts and installing the correct nylon buttons for the cantrail connections.
- Replacing the cable on the driver's door window that had come off the tracks and snarled. This effort made much easier by searching the archives and finding out about Alex Black's really cool cable/window clamps. Thank you, Alex!
- Adding a window lift motor bracket to stop the motor from vibrating when closing the door. Another great idea learned from searching archives.
- Adjusting both doors so that they latch/unlatch smoothly, without having to lift them or push them down to line up the latch and strikers. Happiness is smoothly working door latches.
Next up is to solve the "hard to start when hot" issue I've got. The car starts instantly when cold, with no choke or just a tad. But after driving a few miles, it doesn't want to start easily. Takes many attempts before it fires weakly. A gas smell causes me to think it's flooding somehow. Once it's running, it runs great. Very odd. I've found threads on this topic, but no obvious solution. For now I'll just avoid shutting it down if I may need to start it right back up.
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Third Gear
the parts you removed are these for sale ? TTR parts ? 5 speed transm; ?
- Mike Spence
Finished painting my gearbox housing, extension and bellhousing - all Ford Green POR. Also got my mainshaft bits laid out for reassembly, hopefully next weekend if not one evening this week.
I found a website that might be useful to others, too - kapwing.com. This website allows you to enter a youtube address and watch a video in reverse. I used it to watch the last 2 of my gearbox dissassembly videos in reverse order to get the sequencing of reassembly.
Henry
69 Elan S4
65 Seven S2
69 Elan S4
65 Seven S2
- SENC
Finally had an hour free in the shop. Got the rear suspension removed
Port S4 required please
Love your Mother
Earth
Love your Mother
Earth
I've finished swapping out the fuel tank and sorting the instruments and pieced the Plus 2 back together yesterday, sorting the last few wiring problems (so I thought) and then charged the battery up overnight and went for a local shake down run this morning. Dropped into my mate Dave to see how his TC rebuild was coming along and took a photo opportunity to compare the +2's rear bumper with Dave's Riley Elf:
And then back home the long way, adjust the fan belt and give her a clean to make up for the months spent in the tent and let the sun dry her off....
No major problems over 10 or so miles, so hopefully will start using her now - but of course the new voltmeter isn't working now I've installed it and put all the trim back...doh.... Lotus Electrics =
Visit me on matthewvale.com
Matt Elan - Fourth Gear
