What did you do to your Lotus today...
Fitted Plus 2 brakes to the front of my Sprint. Disconnected the servo. Also fitted a 26R ant- roll bar. Tried to fit a tandem brake M/C but had carb clearance issues so fitted a different capacity M/C which hopefully should give decent pedal feel. Made a new brake pipe and was about to fill and bleed the system but decided to call it a day.
Mazzini - Coveted Fifth Gear
Mazzini wrote:Fitted Plus 2 brakes to the front of my Sprint. Disconnected the servo. Also fitted a 26R ant- roll bar. Tried to fit a tandem brake M/C but had carb clearance issues so fitted a different capacity M/C which hopefully should give decent pedal feel. Made a new brake pipe and was about to fill and bleed the system but decided to call it a day.
the calipers don't look like Plus2 calipers. of course those aren't stock rotors either.
isn't the Plus2 caliper a Girling PB ?
TED
- tedtaylor
tedtaylor wrote:Mazzini wrote:Fitted Plus 2 brakes to the front of my Sprint. Disconnected the servo. Also fitted a 26R ant- roll bar. Tried to fit a tandem brake M/C but had carb clearance issues so fitted a different capacity M/C which hopefully should give decent pedal feel. Made a new brake pipe and was about to fill and bleed the system but decided to call it a day.
Girling 16P/PB I think, some are metric, some are not. The disc/rotor came from Kelvedon, don't know why I bought it as a standard one would have worked just as well.
Hi Mazzini,
I fitted one of these tandem master cylinders to my S4.
https://parts.westfield-sportscars.co.u ... duct_id=84
No clearance problems with Weber carbs and the associated engine mount.
Colin.
uote="Mazzini"]Fitted Plus 2 brakes to the front of my Sprint. Disconnected the servo. Also fitted a 26R ant- roll bar. Tried to fit a tandem brake M/C but had carb clearance issues so fitted a different capacity M/C which hopefully should give decent pedal feel. Made a new brake pipe and was about to fill and bleed the system but decided to call it a day.[/quote]
Colin.
'68 S4 DHC
- fatboyoz
Unbolted an engine mount so I could jack the engine up, remove the carbs, and re-connect the fuel line into the fuel pump.
When it loosened I had a difficult trip home from about 30 km's away as the car ran on 4, 3, 2, and sometimes none !
Managed 80kph on what sounded like 2 cylinders.
Actually, it sounded more like an air compressor on the move.......
Ralph.
Ralph.
- reb53
Our local Lotus club, PALS (Philadelphia Area Lotus Society) had it's third garage tour of the season at RD Enterprises in Quakertown PA. A great event with lots of back country road driving and hosted by Ray. His Elan restoration is looking very good! It will clearly be an award winner
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Today I got the lightweight body for my "26R", we also said goodbye to our s3 which has been sent off to be sold.
Between us we managed to swap most of the GRP parts and had a good fettle. All of a sudden, the car seems a lot nearer to completion. Our plan will be to try fit everything and the remove it all for the respray.
I'll let the photos do the talking.
Best regards, P
Best regards, P
Peter James Evans
1965 Elan S2 (Early 26R replica)
2001 Citroen Saxo Hill Climb Car
2004 Mini R52
2004 Mini R52
- Elan Peter
Apologies... New Lotus content
Washed it, cleaned it and packed some essentials for my Alps tripstarting tomorrow..
Hull, Holland, Belgium, Luxembourg, Germany, Switzerland, Austria, Italy.... Hull
Also packed two essentials Just in case
Splash it on all over.
Slight off topic, but I believe the lady in the advert became Barry's wife, so be careful how you use it.
https://www.youtube.com/watch?v=C5tLfiu7an4
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
You can't throw brut away, I collect it . Will always have about 3 bottles on standby on the off chance that it works as well as it does in the adverts (never does though)
P
P
Peter James Evans
2004 Mini R52
2004 Mini R52
- Elan Peter
I was age 9 and my brother age 7 when bottles of Brut were amongst the Christmas gifts we received in 1977. We splashed it on and our parents got a call from our school!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
