Lotus Elan
What did you do to your Lotus today...
PostPost by: Hawksfield » Tue Mar 12, 2024 5:07 pm
Hi Quart Meg Miles
40k on an engine that has now done 102720 miles. Well pleased with QED work which was a full service on my head, new valves, guides, seats, special springs, some remedial work on two new followers +0.0005".
Shimmed valves.
Its a pity they do not do any workshop machining now they were very good.
As Iam in my late seventies it should see me out :D
+2s130 1971
PostPost by: Johnny America » Tue Mar 12, 2024 7:07 pm
Hi all, small update on the 1001 jobs that I have to do to get my +2 up to scratch. Hopefully others may find this helpful.
I’ve had my +2 outside for the last week and we have had plenty of rain. I have the interior removed as part of the renovation and found the passenger side full of rain water. On investigating found the following.
1. The ‘drip seal’ above the courtesy light switch is missing on both sides - replacement needed.
2. The hole for the courtesy switch in the passenger side was mis shapen leaving a gap for water to run into.
3. Open hole in the engine bay - ditto above.
4. Rain water bypassing the door seal.
As a solution to the above
1. will replace the drip seals, I’m assuming these are simple rubber lip seals - can anyone post the approx size and a picture please.
2. Removed the switch and sealed the hole as a temp measure
3. Fitted a grommet to the hole in the engine bay.
This has stopped some of the water ingress but the final fix was the biggest improvement.
4. Removed the rubber and filled the u section that attaches the seal to the door opening with non setting butyl sealant. Then refilled the seal making sure it was pushed back tight into the corner sections. This left the seal about an inch short where it joins at the bottom of the door opening. Clearly 50 years of shrinkage. I will replace long term.
Then as a separate job, the H4 headlights aren’t great - suspect they need rewriring. I happened to have two LED H4 replacement headlights that were spare. As I believe LED’s pull nowhere the same Amps as halogen headlights I decided to give these ago.
They are simple plug and play connectors and appear to be must brighter and definitely throw a longer light on high beam. A comparison photo
IMG_9035.jpeg and
I wasn’t sure I would like them before fitting but the ‘white’ light is cleaner looking than the old yellow halogens IMO.
I also like the three spots on dimmed beam.
1969 Lotus Elan +2 4 speed - Barn find and currently undergoing recommissioning.
1979 Lancia V6 Group B Rally Car
Johnny America
PostPost by: Baggy2 » Tue Mar 12, 2024 7:33 pm
Regarding the seal above the courtesy light switches a search on Amazon for:-
"Fafada 4 m 12 x 13 mm Rubber Door Seal Rubber Profile Car Door Edge Guard D-Shape Black"
Will take you to the seal I used and has been brilliant. Unfortunately unavailable at the moment but will give you a good starting point for your search
Regarding your LED headlights I used a 'warm white' version. The colour is obviously a matter taste but I've found the above two mods have transformed winter motoring in the +2
Baggy
Baggy2
PostPost by: Johnny America » Tue Mar 12, 2024 8:11 pm
Thank you very helpful
Johnny America
PostPost by: Quart Meg Miles » Fri Mar 15, 2024 1:17 pm
After three weeks away I started up the Elan: switch on fuel pump, clear immobiliser, press clutch and turn key. Engine turned but didn't fire, so I tried again. Same result.
Had a think about it before realising I hadn't primed the Webers! Floored the throttle four times, as regulation, then did something more interesting for a few minutes, and it was away. Must be getting old in my old age.
This morning it did its normal double 20 mile trip to see friends, most of it on dual-carriageway and even overtook a pair of Ferraris like they were standing still. They were (actually following a lorry) but otherwise only two cars went past and they were doing 90.
Meg
Quart Meg Miles
PostPost by: ElanDNA » Sat Mar 23, 2024 4:40 pm
Hello
Take a post from a 150 year+ old bed made of cherry wood.
After some time on the lathe, today I have once again created a part that I have always missed.
Like everything always to my taste. :lol:
20230610.jpg and
20240323.jpg and
Just varnish and assemble.
Cheers Urs
PostPost by: The Veg » Sun Mar 24, 2024 1:29 am
ElanDNA wrote:Hello
Wow, very cool! Show us how it looks with a finish on it!
2012 BMW R1200GS
The Veg
PostPost by: Lotus54 » Sun Mar 24, 2024 2:34 am
I had no need for an ashtray (66 Elan), I was going to try to make a sunglasses holder, but couldn’t come up with a design I liked.
I had this mid-60s aviation clock (windup, with timer also) for decades. So long I cannot remember who gave it to me. I always figured I would find a good place for it someday. I need to source some nice round head screws, but this mounted it and I could see if fit. I 3D printed the mount.
IMG_8271.jpeg and
1966 Lotus Elan S3- Benelli motorcycles (various)
Lotus54
PostPost by: mjbeanie » Tue Apr 23, 2024 12:40 am
The 71 Lotus Elan Plus 2S 130 is finally on the road after 2 years of relentless restoration work.
I took "Lucy" on her first drive (since disassembly by previous owner), and drove to the annual British car show (302 cars), and had a fantastic time! (In her first return to public appearance, Lucy captured 2nd place in the Lotus Category competition.) It was a great experience.
IMG_2871.JPEG and
IMG_0819.JPEG and
'71 Lotus Elan Plus 2S130 (Type 50/0179)
'70 Opel GT
'67 Sunbeam Alpine
'88 Porsche 924 S
'67 Elan S3 DHC
mjbeanie
PostPost by: alan.barker » Wed May 08, 2024 10:35 am
20240508_103017.jpg and
Put "Little Lo" out in the garden for a few photos after her winter facelift, well pleased
PostPost by: pharriso » Wed May 08, 2024 3:14 pm
Alan, looks absolutely perfect!! Enjoy :D
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: berni29 » Mon Jun 10, 2024 4:27 pm
Hi Guys
Fitted my minilite-alikes that were originally on a 60's/70's Alfa Junior. This is to my Spyder Zetec chassis with Sierra running gear so a 4*108 PCD. The poke is bigger on the Alfa wheels so I used spigot rings to bring them down to the Ford 63.4mm. I think the ET is about 38 on these wheels. Tyres are 175/70/14 which is the same rolling diameter as standard 165/13/82 tyres.
This seems to be giving me a track that is about 3/4" too wide at the moment, but the body is not on yet so with the suspension more compressed and at it's correct height this could increase by 1/4" I would have thought to give a track of 55" at the back and 54" at the front which would be 1" more than standard, so 1/2" a side.
I really hope that this is not too noticeable. I cannot live with the stick out wheel look that sometimes accompanies Spyder Zetec cars (due to the 22 offset wheels and not helped by 185 tyres).
Note that in the picture you can see one of the special long reach wheel nuts that I had to buy to use with the standard Sierra studs.
Love the wheels though!
All the best
Berni
IMG_8269 Large.jpeg and
berni29
PostPost by: persiflage » Mon Jun 17, 2024 11:38 am
My recently acquired 130/5 has been filling the garage and house with petrol fumes. The previous owners had the vent system modified by one of the UK major Elan/+2 specialists.
I’ve just confirmed that the mod has been done incorrectly and the tank was still venting to atmosphere from two points :roll: … The original right hand vent and the modified fuel filler neck which the right hand vent was supposed to be connected to.
If in doubt always check.
Looking forward to not having to leave the garage door open 16hrs a day. Simple pleasures eh? :D
persiflage
PostPost by: mark030358 » Sat Jun 29, 2024 10:00 am
Well I took Mr Black to France, Italy, Switzerland and Austria.
Not an Elan granted, but another fine Lotus...
IMG_2049.jpeg and
IMG_0367.jpeg and
IMG_0368.jpeg and
IMG_2059.jpeg and
PostPost by: ElanDNA » Sat Jun 29, 2024 1:26 pm
The Veg wrote:
ElanDNA wrote:Hello
20240628_143007.jpg and
Fitted yesterday, tested today, feels good :D
Not the best photo :mrgreen:
Urs
PreviousNext
