What did you do to your Lotus today...
Mileso wrote:Then tried to change front brake pads and failed miserably and need to figure out how to push pistons back. I presume undo bleeder to release pressure?
It should not be difficult, I generally use a broad screwdriver between the pad & disc on the edge of the pad (after removing pins. Your piston(s) make be seized?
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
+1 to what Phil wrote.
If the pistons are seized, then if you do push them back and fit new pads, then chances are when you first use the brakes they will stick on.
Mazzini - Coveted Fifth Gear
1. Firstly take the top off the master cylinder to stop fluid spraying everywhere when you push the pistons back and fluid returns into the reservoir.
2. Remove wheel and remove pad retainer pins.
3. Remove one pad and then using broad blade screwdrive or tyre lever using disc as pivot lever/push piston back into caliper. Remove other pad and do the same with the other piston.
No need to buy any other tools or undo bleed nipples. Note if you start undoing bleed nipples you will need to fully bleed the system after the pad change.
'71 +2 S130/4
'71 +2 S130/4
- alanr
If the pads are well worn, and will be replaced anyway, I usually do the chisel/screwdriver trick before removing the pad. You can actually see the gap increasing so you will know there's some movement at the piston.
If I wanted to keep the old pads, after removal, I would try and use an old pad backing (minus the friction material) as it also protects the piston against potential damage. Yes, I've seen caliper pistons and seals that have been "butchered" by over-enthusiastic use of pry bars etc.
1968 S4 FHC
1968 S4 FHC
- smo17003
Changing disc pads is a basic DIY car maintenance job on any car.
Please don't take this the wrong way but if you are struggling to do this or are in danger of butchering piston seals or anything else connected with the brakes then please get someone else more car maintenance savvy to do it for you. Your life in an emergency braking situation may depend on it!
Alan.
Alan.
'71 +2 S130/4
'71 +2 S130/4
- alanr
alanr wrote:Changing disc pads is a basic DIY car maintenance job on any car.
Alan.
No problem/offence taken - well used to cycle maintenance but can't believe everything seems to have its particular issues on the Elan, so just checking I am not being dull - and yes, I may well take it to a garage after all! Update - pads changed - I just needed to be 'stronger' encouraging pads back. ta.
- Mileso
Lifted the body off my plus 2. First time in around 30 years. Time for a clean up and paint touch up of chassis and strip, inspect and rebuild of the suspension and steering. I probably will not make much progress in the next few months but hope to get into it more seriously later this year.
Jacked it up until I could slide a couple of beams under the body above the chassis
and then lifted with chain blocks from roof rafters.
Chassis in good condition, just needs a clean up, the Australian climate is kind to cars
it would have been easier on the MaxJax but that side of the garage is for the Elan and Trailer
- reb53
While technically correct, it is the fluid in the caliper that seems to suffer the worst. Heat, rust, possible moisture ingress past the seals. Rather than squirting grotty fluid back up into the system, I usually release the bleed nipple and discard the fluid displaced by pushing the piston back. Propping the brake pedal partway down with a block of wood stops any fluid going back into the master cylinder. I don't think it is necessary, but since I already have the wheel off, and a spanner and pipe on the nipple I do give the caliper a quick bleed while I am at it.
71 Elan Sprint (to be restored)
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Took delivery of these:
And will mount them with these;
one each of Michelin XAS FF 155
Michelin XAS FF 165
Avon CR6ZZ 175/70
Pirelli CN36 175/70
and we'll see what works best.
I'll post the results in a different thread once done
Michelin XAS FF 165
Avon CR6ZZ 175/70
Pirelli CN36 175/70
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
661 wrote:Took delivery of these:
Michelin XAS FF 165
Avon CR6ZZ 175/70
Pirelli CN36 175/70
With that combination, You might find it pulls to one side under braking!
32 Standard 12
32 Standard 12
- Andy8421
Did the strip down on the 5 speed box to replace 4 the gear bulk ring.
- mbell
Andy8421 wrote:661 wrote:Took delivery of these:
Michelin XAS FF 165
Avon CR6ZZ 175/70
Pirelli CN36 175/70
I would be more concerned with different rotation under power L & R. But, the tyres should be soft and low enough pressure the diff may not care
Love your Mother
Earth
Love your Mother
Earth
- Location: RACECAR spelled backward, is——RACECAR! The Faster You Drive...The Slower You Age
Michelin XAS FF 165
Avon CR6ZZ 175/70
Pirelli CN36 175/70
That Is a thousand pounds worth just to try!!! I think I will stick with my very nice handling £55 each ones!! D
Michelin XAS FF 165
Avon CR6ZZ 175/70
Pirelli CN36 175/70
- TBG
I can't believe you are really going to mix 4 different tyres on one car? I think you are just trying to wind us up!
The handling would be just terrible!
'71 +2 S130/4
'71 +2 S130/4
- alanr
