What did you do to your Lotus today...
h20hamelan wrote:Though the 1/2 shafts coming from Col at ElanTrikbits I am guessing they may use a different supplier.
I would expect so. All these shafts being based on VW CV joints means there are likely quite a few suppliers of CV boots. My guess would be at some point the manufacturer of the Rdent/DBE shafts unintentionally bought a batch of boot with issues. These were fitted to a batch of shafts that were sold and some time later had issues.
Its likely that a newer batch of boot has been bought and is being used now for the shafts by the manufacturer. So unlikely to be issue with new shafts.Hopefully good quality boots can be found and fitted to the shafts that do have issues and then they give many years of service.
- mbell
"All these shafts being based on VW CV joints"
Not so - mine are Sierra 4x4.
- TBG
Same for mine
Same for mine
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Lowered it of my lift for first time in three months and did a few miles of testing around the neighborhood. Few noises but found the issues and fixed them.
In the last 3 months I've been replacing the rear shocks and addressing historical doughnut failure damage which has involved quite a lot of work and parts to complete. This has included:
- New shocks
- New wheel carier
- new adjustable height shock tubes, new springs and lotocones
- new wheel bearings
- new pinion seal on diff, new mounts, clean/paint
- new rear arms
- two chassis repairs and chassis cleaning/painting
- New rear brake discs
- new custom adjustable hand brake rods
- under side body repairs
Mostly done as hour here and there in the night after kids in bed.
Tonight I am enjoying a few well earned beers.
- New shocks
- New wheel carier
- new rear arms
- mbell
Great result, Mark, now you can have some fun driving it. I miss driving mine but its reliability at the time was wrecking me and it had to go. I hope your kids still fit in the back!
Meg
Quart Meg Miles wrote:Great result, Mark, now you can have some fun driving it.
Thanks, it been nice just to drive it around locally a few miles to start testing it. I've some more jobs to do on it thou, like fit the matching front suspension, fluid changes, etc etc. Those should be much shorter and less stressful jobs thou. So will be test driving it between them.
Planning a 2,500 mile road trip in it later in the year, so need to get it in order.
Quart Meg Miles wrote:I hope your kids still fit in the back!
They do fit but not with the car seats they still require. There also the lack of rear seat belts. I have mixed feeling about sorting that and taking them out it it as they get bigger. It would be fun it use it as family but there is so little crash protection when up with the massive pickup trucks and SUV here I am very hesitant to do it. Especially given the terrible driving standards here and generally the larger the vehicle the worse the driver...
- mbell
Adjustable A frames with polybushes, Col's amazing CV's
and lots of string
and lots of string
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Today I fitted a 123 dizzy and programmed it with the escort twincam advance curve listed here. Will experiment more but need to re setup the carbs first.
Yesterday I rebuilt the clutch slave cylinder as it's been weeping a little. Unsurprisingly I don't think I've got it fully bleed or adjusted quite right. Will probably go wedge the peddle down and hope it fixes it self!
- mbell
Went to the rolling road and sorted a few problems. Does anyone have a ratio of power at the wheels versus power at the engine? I expect Rohan does! D
- TBG
Incorrect country sticker there, David.
We now have to replace GB with UK.
I like being Great!
I like being Great!
Visit www.lotuselansprint.com
trw99 - Coveted Fifth Gear
Tim, I am great not united..........................D
- TBG
This is a delayed response to Steve Lyles and others-My CV joints are about 10 years old with 2500 miles on them-placed prior to my ownership from RD enterprises. I tore one of the boots last year while raising the back end for brake work even though I did it slowly and not too high. The boot rubber separated from the metal flange and didn't tear centrally-the others were fine. So now I am extra careful with raising the back end-thought that with these CV axles the drop wasn't supposed to be too much but once again my ignorance has struck!
Cheers, Mark Whitaker
69 Elan S4DHC
45/8396
69 Elan S4DHC
45/8396
- mwhitaker
- TBG
I haven't seen a ratio, but the difference on my car was about 19 hp.
- webbslinger
I had understood that chassis dynos did a 'coast down test' to estimate tyre / roller and transmission losses. These are then added back to the HP numbers at the wheel to get an estimate of HP at the flywheel.
I think the fancier shops are able to estimate the losses at different roller speeds so are able to add a 'loss curve' into the HP curve to give a curve corrected for different losses at different engine RPM.
This doesn't capture losses which are power dependent - perhaps the gears have more friction when loaded, or the tyres more hysteresis losses when hot, but I guess it is better than nothing.
Andy.
Andy.
71 Elan Sprint (to be restored)
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
