What did you do to your Lotus today...
Got the car running and moving for the first time since the bonnet was stolen & the car moved to a barn to sit out Covid....
Clutch freed off after a few minutes running & heat cycles. Brakes fine apart from rusty disks.
Interior smells of mice.. eugh!
Jeremy
Jeremy
JJDraper - Coveted Fifth Gear
Adopted the Lotus position of upside down in the footwell to replace the brake master cylinder pushrod, with one of the original length.
'72 Sprint
'72 Sprint
- richardcox_lotus
I did some tire mounting, I always do it yearly to ensure everything is balanced. Aside from that, I clean the car in preparation for the workweek.
- jannhall
Seamus, seeing the photos of your Elan reminds me of an old mate from my time on UK, Tony Lamoury who's Sprint was in same colours. I had an S4SE DHC, Tony his Sprint DHC and another mate Boob Cooper with yellow over white Sprint, all lived around Petts Wood, Bromley and Orpington.
We had a memorable trip to Le Mans for the 24Hr race.
Good times
V
Good times
V
- vstibbard
Long overdue suspension refresh.
Mission creep has set in and I'll get the diff rebuilt with an LSD and Atlas outputs. Have decided to ditch the Spyder driveshafts. New rubber/poly all around. Adjustable rear lower arm. TTR shocks and springs
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Pulled the ARB yesterday as it was knocking on the chassis brace bar, replaced rubbers quite easily took longer to rub down to paint the bar.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
Fiddly, maybe, but 'nightmare'? If it's got the original style knurled retaining nuts and bracket you reach behind the dash and remove them by feel, then pull the speedometer out of the dash and disconnect the wiring and drive cable when it's easy to see what you are doing.
On reassembly, tidy the wiring (ensuring a bit of slack) and the drive cable run to make it easier to do the above next time, at least.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
TBG wrote:Well yes - but it hits the steering column and indicator jobbies and all else besides. No clearance obvious. D
Steering column length is adjustable, so loosen its clamps (at 3 and 21 in diagram) and pull away from the dash.
