Page 81 of 122
Sun Mar 21, 2021 6:48 am
by Mazzini
Gentlemen, thank you all for your kind words.
Without the help of Mike Ostrov, the Elite would still be just a pile of bits.
Have a good Sunday
Sun Mar 21, 2021 4:22 pm
by Sploder90
Looks stunning Rob. You should be well proud of what you have achieved
One of the all time great cars.
Jealous? You bet!
Mel
Sun Mar 21, 2021 6:01 pm
by Mazzini
Thanks Mel! Hope all is well.
Mon Mar 22, 2021 1:57 pm
by baileyman
Elites are going nuts. One just went for huge money on BAT even with 40 year custom paint and a very tired interior.
Meanwhile, I have found a Kubota tractor alternator is my replacement to fit the 1820, so I hope to be on the road again soon. Oh, also on Saturday son and I dragged home VSCCA-logged SB1416. And I was priced out of an 03 Esprit that went huge. Hate that. John
Sat Mar 27, 2021 11:47 am
by TBG
First wash of the year to get the mud off! Second wash in the Autumn!!
Sat Mar 27, 2021 5:10 pm
by trw99
You’ve only gone and washed all the orange off yer indicators, David ...
Sun Mar 28, 2021 1:22 am
by baileyman
Oh, spent the day modding a Denso copy alternator to fit in the crampt Elan space. Got a large diameter pulley attached, which required making two spacers to lift it off the housing, two because one disappeared on the floor. Investigated what the terminal labels all meant, and found there must be thirty seven different labels for the four or five possible functions. Rewired for a different connector. Fitted to the existing brackets, designed for this housing. Discovered the hot out, known variously a A, B, and B+, wanted to occupy the same space as the steering column. Removed and pondered how to move the A, B, B+ out of the way. Rotating the case was a possibility. Made progress separating the case. Then found that to do the job the entire thing would have to be reduced to bits. Cleaned up. Visited ebay for a similar cased alternator with a repositioned A, B, B+. But what else is there to do for an entire day?
Sun Mar 28, 2021 9:10 am
by TBG
You’ve only gone and washed all the orange off yer indicators, David ... says Tim
So much more elegant Dear Boy - so much more elegant!!
Sun Mar 28, 2021 12:01 pm
by 661
Finished making a cover for the M/C and moving the pedal box over a tad to avoid as much wheel rubbing as I can.
Sun Mar 28, 2021 1:17 pm
by Pastapesto
Hi Graeme
That's lovely looking work you have done there.......I'm very impressed!......
May I ask where you purchased your 2 Fixings you used from?....I was chatting to a friend this morning about using them on the engine cowel on his light aeroplane and he wanted to know where you can buy them? He wanted aircraft grade but they look exactly the same as the ones you have used.
Many thanks.....how long do you think before the car is finished? I would love to have a good look at what you have done!
All th best
Adam
Sun Mar 28, 2021 1:32 pm
by nmauduit
661 wrote:Finished making a cover for the M/C and moving the pedal box over a tad to avoid as much wheel rubbing as I can.
nice touch...
ps: the Dzus fasteners can be sourced from Merlin Motorsport (no affiliations)
Sun Mar 28, 2021 10:03 pm
Re-instated the ballast coil system on Friday night but today was test day. Seams to be working well and car send to run a little better even thou it shouldn't make a difference.
Mon Mar 29, 2021 10:06 am
by 661
Pastapesto wrote:Hi Graeme
All th best
Adam
Aircraft spec fastenings are available from the usual suspects, I use Trident racing
The car has run around the block. I have a track day at Goodwood in 3 weeks
Thu Apr 01, 2021 6:51 am
by 661
Thu Apr 01, 2021 9:31 pm
by persiflage
Took delivery of a carpet set ... was expecting underfelt
