Page 74 of 122
Tue Nov 24, 2020 3:23 pm
by Sploder90
Quart Meg Miles wrote:Sploder90 wrote:Baseball cap sufficed...( I cheat though as have a wind deflector
As a Yorkshire man couldn't you manage a cricket cap?
I'm still wearing bobble hats
sans bobble.
The baseball (Rounders
) cap is colour coordinated BRG with ACBC badge....
A blue YCCC would just clash
Was also worried that a flat cap would blow off & tempt the whippet to leap from the car to give chase....
Have noticed that lockdown 2 shopping trips appear to be getting longer
Tue Nov 24, 2020 3:58 pm
by Bud English
TBG wrote:"Mmmmm. Oil pan..."
No - it is a sump.........................
Lotus parts manual says that it's an "A026E6083 (2731E6675) Oil Pan"
Tue Nov 24, 2020 4:02 pm
Now that's Sumpthing to talk about in the Pub.
Tue Nov 24, 2020 4:56 pm
by Quart Meg Miles
alan.barker wrote:Now that's Sumpthing to talk about in the Pub.
Oh no, a sump pun!
Tue Nov 24, 2020 5:35 pm
by Sploder90
Bud English wrote:TBG wrote:"Mmmmm. Oil pan..."
Oh no, confusion in Lotus literature.. The workshop manual says sump..
I would normally pop down the pub to work out such a conundrum but we are unfortunately denied this option of old fashioned social media
Wed Nov 25, 2020 1:50 am
by SENC
Can't believe a sump pan causing controversy. Particularly with a great set of uprights beside it just awaiting trunnions and grease.
Thanks Rob.
Wed Nov 25, 2020 9:29 am
SENC wrote:Can't believe a sump pan causing controversy. Particularly with a great set of uprights beside it just awaiting trunnions and grease.
Thanks Rob.
A six bolt crank sump is about the most valuable thing on a twin cam so it deserves some detailed discussion over a beer or two. Trunnion greasing versus oil is just hot air discussion you bring up when you feel like upsetting those whose oil their trunnions
Wed Nov 25, 2020 2:20 pm
by joe7
If I'm not mistaken that appears to be a 4 bolt sump.
Wed Nov 25, 2020 3:56 pm
by SENC
Indeed it is a 4-bolt/rope seal, Joe, a backup for my Seven whose sump has clearly been in a few "scrapes". Maybe not as valuable, but just what I needed. Acquired from one of our esteemed lotuselan.net members.
Wed Nov 25, 2020 10:35 pm
by Hawksfield
Swapped over the passenger seat for the drivers seat to share the wear and tear, drivers side is showing signs of nearly 50 years of use.
I can manage the backrest adjust ment ok
Quite pleased with the result
Fri Nov 27, 2020 8:43 am
by miked
I went for a drive in the countryside. Started first turn after about 6 weeks and the first time i tried the chokes on my bike carbs. Only needed it for the actual start. Overall pleased with them. Staying in balance and very even running through the rpm.
I have a mix of gear oil and moly grease in my trunnion gun
Sat Nov 28, 2020 7:22 pm
by SENC
A wet morning unfit for much, so spent some time cleaning up hubs, axles, and uprights before putting them away for a future project. Always rewarding to get old rusty bits looking the part again.
Sat Nov 28, 2020 8:40 pm
by MrBonus
Has anyone had an oil pan gasket fail? I’m noticing a decent but not terrible oil leak and it seems to be coming from somewhere near the alternator bracket with some oil buildup on where the sump meets the block.
It may just be my cam cover gasket taking the long road down but it’s so hard to tell where it’s coming from and I’m at a loss.
Sat Nov 28, 2020 9:10 pm
Not uncommon for oil to be pushed out of the dip stick pipe.
Sat Nov 28, 2020 10:25 pm
by TBG
"Not uncommon for oil to be pushed out of the dip stick pipe."
Only if you have an over pressurised sump. Rings?
