PLEASE HELP fellas: oil pump rotor/stator needed EXPRESSO!
i desperately need to know WHERE to get the following vital parts for my HART 5 port dry sump pump!!!:
outer rotor - od 40,56mm / 1 19/32": height 22,2mm // inner rotor or stator od 29,73mm / 1 11/16" h: 22,05 inner rotor id (bore) is 12,7mm / 1/2" and has a machined/milled slot for the key: 3,18 (prob 1/8") - the scavenge side isn't as important, but i'd also buy those! ------------------ maybe/hopefully you have these 2 parts in your spares: i went to qed, pace, titan, burton but no dimensions - i'd really appreciate help or even better the parts in the mail next monday - many many thanks gentlemen sandy (the alfa man who SEALED my engine DID NOT use RTV or wellseal between backplate and block!!!!!) can u imagine the leakage??
- el-saturn
Sandy, PM sent, Nigel F.
- nigelrbfurness
