DVLA History Records
I give up, I have searched this forum and DVLA's web site for data on applying to DVLC for held history on a vehicle.
Can any kind soul give me a dirct link to the required form or the DVLA form number
Dave
Yes I know I cant spell, but can weld, spray paint, lay grp and rebuild engines.
69 S4SE DHC
Dave
69 S4SE DHC
- DaveAlmey
Form V888
You have to download it and post with a ?5 cheque.
https://www.dvla.gov.uk/dvla/data/relin ... quest.aspx
Jason1 - Coveted Fifth Gear
That's what I used as well. I just said I'd owned the car for years, it was in the historic class and wanted to learn a bit about the history which seemed to do the trick.
It wasn't a quick process by any means and I'd almost given up when a thick envelope arrived with lots of photocopied documents from which I could plot it's life around the midlands area. The bumph also included documents for someone else's car as well, so check carefully !
UAB807F - Fourth Gear
I tried this too but got very little info back, just a few photocopied V5's, half of which are unreadable & nothing from before July 75 (car is 1972), in fact, I didn't get anything I didn't already know. It just depends on what the DVLA still have on your car, unfortunately, in my case not very much & not really worth the fiver. You'll need a valid reason for the enquiry, & like Brian I used the "trying to compile a history file on my car that I've owned for years" as well. I was at first told that it wasn't a good enough reason but then they changed their minds & said OK ???? It's also been suggested to me that a second enquiry might throw up more info but not sure how that could be unless some DVLA staff look harder than others ?
Regards, Tim
Regards, Tim
- Orsom Weels
I have done it twice for my +2.
I didn't get the original V5 in either enquiry but did get different info in both enquiries. The first gave me a document relating to the import of an Audi. The second did get me a form used to book an identity inspection which confirmed the original Lotus chassis number.
I did mine over a decade ago, I think it was called information from records.
I got photocopies of all the V5's that were issued for it including my own application for a V5 plus a photocopy of the original logbook showing the names and addresses of all the owners prior to when it was submitted to the DVLA in 1977 and the first V5 issued.
One of the owners showed her title as "Lady"
- Chancer
DaveAlmey wrote:Hi,
Hi Dave
Not sure if this is what you require - but will evaluate current status
https://www.taxdisc.direct.gov.uk/EvlPo ... ution=e1s1
mikec2126 - New-tral
Users browsing this forum: gav and 19 guests
