MOT Fail
Fri Apr 20, 2012 5:31 pm
by pauljones
Help required gentle men,
My plus 2 has just failed is annual test,
Handbrake not working on one wheel
Wiper blades need replacing
Passenger door not opening from the inside
Wiper switch needs replacing
Headlights go up and down with engine revs
Anyone got any ideas on fixing the light situation,It has all been stripped out for a re wire,could it be that a vacum/air line is put in wrongly? does anyone have instructions on correct routing?
The others i think are fairly simpleto fix
HELP HELP HELP so close yet so far
Paul
Re: MOT Fail
Fri Apr 20, 2012 5:50 pm
by simonknee
When you go for a retest I would suggest my MOT place but might be a bit far away.
elan-f15/mot-pass-t25050.html They are completely legit but they understand too.
"Wiper blades need replacing" seesh.
As to the headlights you might want to check whether the vacuum pipes on the dash pull switch are the correct way around.
There is a right and a wrong way for all the pipes in the vacuum system and it sounds like the way you have it at present is not isolating the pods from manifold pressure.
Simon
Re: MOT Fail
Fri Apr 20, 2012 5:59 pm
by Jason1
My lights used to do that. I propped them up with 2 pencils for the MOT. It was a leak in one of the pods.
The handbrake is prob a seized pivot pin on the caliper. Try adjusting it first.
Door not opening could just be the rod popped off. You need to get the door card off and see what is happening.
I would say your car did pretty well; just a few little bits to look at.
Good luck
Jason
Re: MOT Fail
Fri Apr 20, 2012 10:47 pm
by AHM
Duff non-return valve?
My S3 is booked in for Monday... At the moment it doesn't have any brakes, driveshafts, seats, fuel tank and I have 4 pages of to do list... You did well!
Simon
Re: MOT Fail
Sat Apr 21, 2012 6:03 pm
by pauljones
Simon,
Thats a fair bit of midnight oil to be burned. Looks like I was let off lightly then,Cant wait to get her on the road Im getting a bit impatient now...Cant rush these things now can we?
Paul.
Re: MOT Fail
Sun Apr 22, 2012 11:34 pm
by AHM
Looks like I will be making a phone call first thing... not ready!
