Lotus Elan
Canada calling
PostPost by: dbarton62 » Sun Jan 03, 2016 11:41 pm
Hello from Canada, ex Brit from Brum......Aston to be exact.
I am in the process of acquiring a 1969 Elan plus 2.
Car is complete cosmetically but lacking engine and transmission.
I will be looking to keep the car appearing as it came from the factory but with a surprise under the bonnet.
I have modified several British sports cars including a 1969 Marcos with a 3.5 Rover and 4 speed. A 1974 TVR 2500M with a Ford 302 and 5 speed and a 1958 MGA coupe with a Ford 302 and 5 speed.
I will post a topic in the appropriate forum.
Glad to be here.
Dave
dbarton62
New-tral
PostPost by: stugilmour » Mon Jan 04, 2016 5:13 pm
Welcome from Calgary Dave. Where are you located?
Stu
Stu
1969 Plus 2 Federal LHD
PostPost by: dbarton62 » Mon Jan 04, 2016 5:20 pm
Kitchener ONT.
Just about an hour West of Toronto
Dave
dbarton62
New-tral
PostPost by: The Veg » Mon Jan 04, 2016 5:51 pm
Welcome Dave!
1969/70 Elan Plus 2 (not S) 50/2036
The Veg
PostPost by: daholmes1967 » Mon Jan 04, 2016 6:38 pm
Hi Dave
I am just down the road from you in Woodstock ON and have a 73 Plus 2, send me a PM and we can connect sometime.
Dave
daholmes1967
New-tral
PostPost by: donselan » Mon Jan 04, 2016 9:46 pm
Hi Dave,
And I am just up the road from you in Erin ON. I have 2 Elans but not +2s. I am aware of 2 other +2 Elans in the area.
Don
Don Fysh
S3 Elan FHC 36/5607
S3 Elan DHC 45/6646
donselan
PostPost by: dbarton62 » Tue Jan 05, 2016 5:29 pm
Hello all,
Great to see so many locals.
We will certainly need to get together once my project gets rolling.....if you don't mind me picking your brains??!!
I have been in touch with Len Mason in Orangeville also regarding plus 2 bits. He says he has a decent inventory of used stuff.
Dave
dbarton62
New-tral
PostPost by: saildrive2001 » Wed Jan 06, 2016 3:32 pm
Welcome Dave, I have a 69 S4 Elan & I live in Burlington. If you are down this way let's get together for a chat. I'm originally from Lancashire near Burnley.
Keith
Keith Marshall
saildrive2001
PostPost by: TimBJ » Wed Jan 06, 2016 4:01 pm
Hi Dave
I am in Puslinch, just south of Guelph.
I have a 71 FHC Federal Sprint, together but not running yet.
A 1966 S3 DHC in pieces and a 1967 FHC Super Safety basket case.
Good luck with your project.
TimBJ
New-tral
PostPost by: stugilmour » Fri Jan 08, 2016 3:07 pm
Small world Dave. I got my car from Ken Mason in Orangeville a number of years ago and drove it across the country to Cowtown.
Best of luck with the project. Curious on drivetrain you have in mind. Anyway, you have landed at the right place on the interweb; lots of help here. Stu
Stu
PostPost by: dbarton62 » Fri Jan 08, 2016 7:24 pm
stugilmour wrote:Small world Dave. I got my car from Ken Mason in Orangeville a number of years ago and drove it across the country to Cowtown.
Hey Stu,
Depending on when you did buy your Lotus from Len I likely saw the car.He used to hold annual summer meets at his place and I do recall a couple of Elans, a beige and a yellow?? I think.
Anyways I do not have my plus2 in hand yet but am putting in serious inter web seat time collecting info on physical sizes of engine and trans combos in preparation for this build. I will start a thread to document but until I get the chassis and take measurements I would be jumping the gun on any plans.
I do like the Ecoboost and Miata NC 5 or 6 speed combo. I think it is compact enough and with 350 ft/lbs capabilities it would make the plus2 wonderful machine. The purists will frown no doubt but for me a modern drivetrain under a classic shellis where it's at.
Dave
dbarton62
New-tral
PostPost by: stugilmour » Mon Jan 11, 2016 3:27 pm
Sounds like an excellent project. My car was purchased as a white Plus 2; hard to believe it was over eight years ago now! He had a Plus 2 convertible when I was there. Here is the blog of my drive across the country....
free-parking-f45/half-way-across-canada-lotus-plus-t16492.html
As you have probably found out, the Ford drivetrains are the well trodden path. We have a chap locally that has been working on an older Toyota TC and five speed combo for a number of years. My car now uses a Ford MT75 five speed with the stock Lotus TC. More power from a modern engine would be great!
Most of the drivetrain conversions use some form of Spyder frame; excellent company to deal with. Although my frame landed in Canada was a bit spendy, the Spyder guys assisted me with loading a wide array of other parts I needed in the same box. The Spyder modified engine mount design and cut out front cross member really increase the clearance.
The critical Plus 2 engine dimension tends to be the compromise of the sloped bonnet to the cam cover / front plate / cam belt and the oil pan clearance. Check out Mark's Plus 2 with a BDA and reworked bonnet for reference. I think the Duratec guys typically mod the pan to increase road clearance. Other tight spot is the exhaust routing around the bell housing.
All he best with the project and have fun with it. These are great cars when finished up, and can easily handle the increase in power.
Stu
Stu
PostPost by: dbarton62 » Mon Jan 11, 2016 11:28 pm
Great diary Stu.
I am a journeyman fitter welder by trade so any work required to fit a non stock drivetrain will hopefully not be a big issue. It remains to be seen.
Dave
dbarton62
New-tral
