PO bodgery stories
Posted: Tue Sep 22, 2020 8:33 pm
For a long time I didn't know what a PO was .. Previous Owner
We do love to refer to the PO , usually when we find some hideous bodge... Even though some of us are the PO !
Sometimes I have asked.. why did I do it that way ??
Over the past weeks I have been recommissioning a car... To discover:
The water pump bolt for the alternator bracket had rounded off so they used a 10mm bolt from the water pump case so the thread in the block is now elongated.
The alternator was set back from the crank and water pump pulley so the belt was twisted
The entire water system was full of pink/white sludge
The radiator had a rust hole filled with a screw... The car had been jacked using the bottom of the radiator so it was crushed flat, some braising to fix a leak at the top hose had welded the fan shroud to the radiator.
The temp sensor is a capillary but when they had unscrewed it from the manifold they had broken the capilliary
The thermostat was wedged open with crusty sludge
The thermostat cover is cracked because the thermostat is not for this car at all so it doesn't fit.. when clamped down it fouled on the thermostat
The heater out and in , one on the manifold has had a bolt welded into it, the one on the pump has a bolt welded in and then cut the head off.
The clock in the tacho had a black bottle top glued over the clock face.
The exhaust manifold didn't have a gasket they had used silicone !
The manifold to pipe had been put on with nylocs...
The central section of exhaust pipe is...2" Copper tube
The exit pipe from the silencer is cut at an angle and was obviously a bit of scrap welded on to make it longer
The radiator fan was wired up to the rear fog light switch and the brake lights are wired to the numberplate lamps..
The oil cap has a plug chain attached to it... For no reason...
And today I discovered what the white and pink sludge was for... After replacing every part of the cooling system apart from the pump I got it started to discovery the water pump leaks from the pulley.. So it must have been a couple of doses of radweld.
Please share you worst PO bodgery ! Or even your own nightmarish bodges if you dare confess
