Help i.d. this Weber part, not DCOE, grose-jet
I've got eight of these valves, or jets, that came to me in a cache of parts. They come in a
small, roughly 2 inches by 3 inches, envelope printed for D &G Valve Mfg, no longer in
business. The ink stamped part says 'Weber 505 .084'
The valve / jet is 1 3/4" and comes with 2 washers. Some research indicates this might
be for some downdraft Weber but I'm hoping someone in our community can identify
this.
this.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
No answers here for you Greg, maybe worth sending your info to: http://www.weberjets.com suspect they?ll be able to help and/or buy them from you.
elanfan1 - Coveted Fifth Gear
I've used Grose valves when I was in the US, but of the shorter kind. These look quite similar to Type 504 (rather than 505?) then would fit IDA 3BBL carbs (2 per carb) :
http://www.97330.com/GroseJet_id_sheets ... o_inc.html
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Grose-Jet: "2 balls do the trick!" That was the ad in Road & Track way back when I was a pre-teen and thought it was hilarious.
https://jimsgarage.wordpress.com/2006/0 ... grose-jet/
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
Interesting, I have used Grose-Jet replacements for float chamber needle valves in Weber carbs for quite some time. The valves you have are certainly not for DCOEs. The post from nmauduit seems to provide the answer.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
