Most satisfying long term upgrade
• Page 2 of 3 • 1, 2, 3
Rebuilt TC engine by Quicksilver Race Engines
TTR full 2" exhaust system (headers to muffler)
Coil over shocks
TTR spline drive shafts (no donuts)
This website which was immense help during my rebuild!
Coil over shocks
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
JJDraper wrote:So what has made other owners quietly satisfied over the years with something that has just worked?
Jeremy
The girlfriend
...well... I figured that as she loaned me the deposit for the Lotus [I left my cheque book at home] I would upgrade her to "Wife"
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
wotsisname wrote:JJDraper wrote:So what has made other owners quietly satisfied over the years with something that has just worked?
Jeremy
The girlfriend
very good. When my girlfriend didn't complain about electric windows dropping into the door when it was raining, not panicking when oily smoke drifted from under the bonnet and not batting an eyelid at several roadside maintenance sessions I did the same !
UAB807F - Fourth Gear
Some more:
Drilling a hole in boot wall and fitting a rubber grommet for filling diff oil. Think it was 1.75 inch. Can get socket in and fill with ease.
Brazing a washer on the dizzy clamp bolt. Pinched idea from Mr Clegg's Tommy bar. Great, put hand under and acts just like a wing nut. No faffing with driver or spanner/socket.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
Jeremy
The girlfriend
When my girlfriend started referring to my elan as ' your little car' and was only happy when I swapped it (and my Excel) for an Esprit - she became my Ex and no, I'm not bitter about the lying, cheating b#!#h at all
- KevJ+2
Most satisfying is increasing the spacing of the pedals so that my size 10 wides only press one pedal at once and it cost nothing.
Modern starter motor is brilliant, and now looking forward, I should have the CV drive shafts fitted in a few days. I expect to be equally pleased with those.
Eric in Burnley
1967 S3SE DHC
Eric in Burnley
1967 S3SE DHC
- ericbushby
Replacing headlights with halogen units and Rewiring with Relays. Made night driving both safe and a pleasure
Mick (Sue) Miller CV Driveshafts
Electronic ignition
TT Front Shocks & Springs (time to replace them now plenty of miles on them)
EBC Pads
Oil breather away from airbox....
Planning to put in an intermittent wiper mode....
Happy with more or less all else as 'original'.
Still in love with my +2 12+ years on
Electronic ignition
EBC Pads
'73 +2S 130/5
'73 +2S 130/5
peterako - Fourth Gear
peterako wrote:Replacing headlights with halogen units and Rewiring with Relays. Made night driving both safe and a pleasure
On my list. Might even consider LED.
Installed by previous owner.
Electronic ignition
Also on my list.
Got Konis thanks to previous owner but they won't last forever.
EBC Pads
Do you like them?
Working on that, after seeing the oily mess in the intake system and all over the inside of the nose.
Hadn't thought of that, but might be useful.
I hope I love mine at least as long. Need to get it back together and on the road!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
I had a diff case with a stripped drain plug hole thread. Fixed it with a Bergen spark plug insert. Worked a treat and the tool even cut a fresh seat. Using a cut down spark plug bottom I brazed the old brass plug nut together. Job done.
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Great thread. Nice to see practical drivability mods in one place. When I was building my car I kind of had to hunt them down.
For those considering intermittent wipers, this is what I installed. Still really happy with the setup...
elan-mods-f31/smartscreen-intermittent-wipers-review-t25502.html
Rewiring the whole car and adding adding additional fuses & relays is top of my list. Have never had anything beyond a loose wire since. Veg, the Halogens are the way to go; completely adequate and period correct. Looked at LED?s for my Esprit, and the cost and hassles are a bit much.
For a cheap and easy Plus 2 mod, grind a bevel on the end of the two hex screws that form the bonnet hinges. Way easier to get the bolt started in the bobbin.
Stu
Stu
Stu
1969 Plus 2 Federal LHD
Stu
"For a cheap and easy Plus 2 mod, grind a bevel on the end of the two hex screws that form the bonnet hinges. Way easier to get the bolt started in the bobbin."
or even replace it with a longer screw , with the pointed end as suggested but also with wing nuts brazed on the ends , so much easier to fit/tighten with ones fingers rather than trying to get a spanner/socket in there...
Those have to be the two most frustrating bolts on the car.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
