Open wheeler gets a birthday
Time for some roundels and numbers
Elfin Monocoque (Twin Cam)
[email protected]
[email protected]
SJ Lambert - Fourth Gear
Oil Pressure Adjustment Hole done
[email protected]
[email protected]
Feels like the gear selection linkage is set up fairly well, wheel alignment is next on the agenda.
[email protected]
[email protected]
Looks a bit better with fuel & a driver's weight of ballast
[email protected]
[email protected]
High tech refuelling rig!
[email protected]
[email protected]
New surround for oil pressure gauge
[email protected]
[email protected]
Ground clearance OK
[email protected]
[email protected]
Thanks Rohan, getting closer every day now - moved the fuel pump up away from the gear selector rod tonight!
[email protected]
[email protected]
Rear view of Richard Carter's chassis 6652 (the one before mine)
[email protected]
[email protected]
And Norm Falkiner's 6654
[email protected]
[email protected]
Mine's bog standard original (new donuts) complete on Imp hubs.
Norm's could be largely original too (Elfin did do a single uni per half shaft in an attempt to beef up the driveline, though it could also be an post factory upgrade from my set up).
Richard's is definitely a post factory upgrade (& in all likelihood the hardiest & most reliable ) - Richard is a former driver to Europe winner (around 1975) & is still extremely quick!!!
[email protected]
[email protected]
I've recommenced work on the original blue bodywork as I've just managed to source some correctly dimensioned/profiled ERW tube for a second set of mirror stalks.
[email protected]
[email protected]
The mirror stalk material has arrived!
[email protected]
[email protected]
