stevebroad wrote:The water test won't work if sticks are hollow. There is no way of telling thickness of tube so no way of working out density based on water displacement. A hollow aluminium stick of the same external dimension as a stainless steel stick will displace the same amount of water, assuming they both sink.
As aluminium is approx half the weight of steel, simply holding them should be sufficiant to be able to tell what they are made of, I would have thought.
Aye, you are only really interested in finding out if the density is near as dammit to Aluminium or common alloys.
I don't think they would bother to make hollow aluminium ones.
If density is not near, then they are probably hollow s/s.
