dull top lacquer coat
Hi there,
I recently purchased an Alfa Spider which had been in dry storage for 8 years. There must have been a small leak in the garage roof because there is an area on the bonnet where the lacquer has "dulled". Is there any way of curing this apart from re-lacquering the entire bonnet?
Same question also applies to another car where a PO has , I think, not completed a good paint job - the lacquer is dull and semi-flat. Again, any solution apart from a full respray?
On a positive note, my Lotus' are really bright and shiny!!
Martin B
Martin B
- martinbrowning
It might just be a thin surface film if you're lucky. Assuming it's unacceptable as it is, and you're resigned to a respray then I'd be tempted to try some T-cut on the worst section. Very gentle application and see if it improves matters on the basis that there's nothing to lose.
The only time I ever sprayed a clear coat system I deliberately put on plenty and then cut it back using 1200 wet/dry followed by G3 cutting paste, finishing off with T-cut & normal polish. With any luck you should have enough lacquer there to get away with at least the last 2 stages.
UAB807F - Fourth Gear
