Eternal Damnation?
Posted: Wed Feb 29, 2012 1:59 pm
I bought some polyurethane bushes for my differential tie-rods and was under the car fitting them earlier today; as is the way with this material it sometimes has a mind of its own. I took the tie rod off, removed the old bits, fitted the first bush and cup washer, put it through the diff carrier and found that the bolt holes through the chassis at the front end of the tie rod were way out of alignment. This was due to the new bush being longer than the tired old item I had removed.
I applied some leverage to the (rounded) end of the tie rod by means of a 14 inch cabinet screw-driver and tried to push the bolt through as the holes came into line; you can imagine that this was like trying to juggle with cats with one hand behind my back. After I had stabbed myself at least three times and the had screw-driver slipped off for the 17th time I let out a very loud and plaintive cry along the lines of "You effing bastard thing...".
I heard a slight noise and imagine my surprise when I looked from under the car and saw two figures transfixed on my driveway- a lady of middle years dressed in rather peculiar fashion with a floor-sweeping dress and beret (she was wearing other garments but I did not take note of what they were); alongside whom was standing and an angelic little girl of about 6 years, also wearing a skirt down to the ground. The lady sort of whispered, "I'll just put this leaflet through your door" and they scuttled off pronto!
Needless to say the bolt slipped in at the next try and then the sun came out.
I have just cleaned up and read the leaflet they left; it seems to be from the Watch Tower Bible and Tract Society of Pennsylvania. Most of the stuff in it is mumbo-jumbo but it does say:"If we want God to listen to our prayers, we must pray in the way that he approves".
My new method of working will be to enter the garage swearing and cursing at the top of my voice before I pick up a tool; presumably everything will just fall into place from then on.
