Engineering Question
Apologies for a non Lotus question...
Can anyone offer any wisdom/thoughts as to why motor manufacturers changed from king/link pin suspension to balljoints
I've got as far as cheaper?to manufacture,less maintenance,but am curious as to whether there were any other reasons-were there inherent problems with king/link?
Your thoughts would be much appreciated!
Cheers,Peter.
Cheers,Peter.
- purplepete
Just a thought Peter but have you ever had the pleasure of freeing off a seized kingpin and fitting and reaming new bushes?
Not yet!!but i might be about to..
i've got the option of using a balljoint front end,or king/link set up..
balljoint set up completely rebuilt new bearings,balljoints etc
linkpin set up rusted/partially seized,but it looks prettier,and theres a clearance issue..linkpin is narrower,which in this case is good-saves a lot of faffing around.
just wondering why the change of design!-my inquisitive brain is forever asking what why how!
- purplepete
Peter
Its all about reducing the part count and ease of close tolerance assembly and reuse of standard components across multiple designs.
A modern ball joint design is cheaper to make and easier to assemble accurately in a car plant and holds its tolerances longer.
[quote="purplepete"] i've got the option of using a balljoint front end,or king/link set up..
balljoint set up completely rebuilt new bearings,balljoints etc quote]
Just as a matter of interest what car/project are you working on............VW ? .......... I cant think what else it would apply to.
Rohan,
Thank you-thats pretty much what I was thinking,tho not quite so eloquently!
Brian,
Yes,its a VW chassis,with a kind of alternative body-hence the clearance issues!
Thank you for answers!
peter.
Brian,
peter.
- purplepete
Users browsing this forum: paddy and 19 guests
