scissor lift
• Page 3 of 3 • 1, 2, 3
Hi Alan,
I've been using a Ryobi RPD1200 drill. It has a two speed gearbox and variable speed and has plenty of torque to operate the lift easily even with a large car like the BMW.
- 111Robin
Thanks for the info!
Alan.
Alan.
'71 +2 S130/4
'71 +2 S130/4
- alanr
I use a stout 1/2 inch Bosch that works really well. I do like the two-speed idea, though, as it does take some time to lift the car to the heights you really want. But, in the end, what is an extra few minutes, really?
-John
-John
John Beach
'69 Elan S4 DHC - A Work in Progress
- jbeach
I agree, the speed of the lift isn't important. I like the variable speed as it gives very accurate control if for example lowering the body to align with a subframe supported on stands. I've used it this way to fit the rear frame on a Mini.
- 111Robin
I have had the EZcar lift since 2014. Fine bit of kit. Great communicator of his business.
The slow speed with the drill is helpful in the sense that you can position the lift and any timber and slowly raise observing that you have not caught anything you should not have. There are quite a few older posts on the forum regarding the lift and its use and accessories.
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
BMW rninet scrambler
Suzuki TC120R trailcat
Suzuki TC120 trailcat
Suzuki K15 Hillbilly
Suzuki TS185K
Elan S4 Zetec
Suzuki TC185
Suzuki Hustler T250
Suzuki TS185K
miked - Coveted Fifth Gear
- phil1800
Trying to decide which is the best lift is not always easy with so many options available. Here is a link to a video where the guy takes you through his thought processes in deciding the most suitable for him. He looks at numerous variations which others may find helpful, also he has produced a further couple of videos on the delivery and installation of his chosen lift which provides one or two tips.
https://www.youtube.com/watch?v=W8XH78atNC4
- tonyabacus
