Tyre pressure gauge
Can anyone recommend a good tyre pressure gauge?
The one I have is proving very unreliable. Its this one (although it was called something different when I bought it):
https://www.amazon.co.uk/Oasser-Inflator-Pressure-Backlit-Quick-Connect/dp/B07HH5MP88/ref=sr_1_21?dchild=1&keywords=tyre+pressure+gauge&qid=1593878845&sr=8-21
There seems to be a big gap between the consumer grade products that do little more than tell you if your tyre is flat or not, and the kit used by professional racing teams up in the £hundreds. I don't need it accurate to the last 0.05psi, but something that would reliably and repeatably measure to within 0.5psi would be great. Can either be stand alone, or airline mounted, analogue or digital.
Thanks in advance for any suggestions.
Andy.
Andy.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
https://www.demon-tweeks.com/uk/longacr ... ch-526447/
0-30 psi works for the Elan ( and Exige) but not for my daily ( Golf)
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
I've always used gauges made by PCL in Sheffield, both for road and race
/https://www.pclairtechnology.com/
1963 Nuffield 460
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
1987 E28 M5 #180
2006 E90 320si
2006 E46 318Ci
2009 Elise R
2016 F11 520d
2018 T6 150TDi DSG
Andrewelan - Second Gear
This is what I use. I have a small compressor in the garage, so this plugs into the air hose. They have a version that’s just a gauge that is also accurate and reliable.
Andy
Andy
- abstamaria
This is also quite good. I’ve had it for 50 (!) years, but understand it’s still available. I thought I would take this photo for posterity.
- abstamaria
For a hand-held, keep-in-the-glovebox, accurate tyre gauge, use a PCL (Pneumatic Control Ltd) gauge, as above. Made in Sheffield and high quality.
I'm still using one my Dad gave me 30 odd years ago, and it is still very accurate.
Available on Ebay, at around a tenner for new, less s/h.
Also Schrader an equally good make.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
Previous :-
- elans3
Here is an interesting new product, a battery-operated tire inflator. It has a digital pressure gauge, as shown in the photo I took. I checked the reading against my analog gauges, and the readings were identical. I have no connection with them, but think it’s an interesting product to keep in the glovebox.
Andy
Andy
- abstamaria
This is what I've been using for many years:
https://www.machinemart.co.uk/p/clarke-30d-airline-tyre-inflator-with-pressure/
Clarke 30D from Machine Mart. Plugs into my compressor for actual inflation but stand alone for checking. Pretty solid bit of kit, and cheap - under £12.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
