Valve spring compressor Sykes Pickavant
Fri Jun 26, 2020 9:09 am
by Andrewelan
Does anyone have experience of this tool and its suitability for the twin-cam engine? My old one is OK for an A-series (Mini days!) but not an OHC engine with deep set valves
Many thanks
Re: Valve spring compressor Sykes Pickavant
Fri Jun 26, 2020 12:53 pm
by 2cams70
Fri Jun 26, 2020 1:04 pm
by Andrewelan
Thanks. Could see link but it didn’t seems to go to a specific page. What make/model was it
Fri Jun 26, 2020 1:14 pm
by 2cams70
Plug this into Ebay search in that case:
Sealey Multi Valve Spring Compressor Petrol Diesel Engines 55-175mm Capacity
Fri Jun 26, 2020 1:25 pm
by Andrewelan
Thanks for that. I may have a offer to borrow one but great back up if it doesn’t suit. Cheers
Fri Jun 26, 2020 5:48 pm
by steveh
Ive got 3 types including SP, given the choice i would buy another one of these at the astonishing price of £9.
Fri Jun 26, 2020 7:53 pm
by Andrewelan
Wow
That good for £9?
Sat Jun 27, 2020 9:55 am
by 2cams70
The ones with the lever action are preferred. Once adjusted to suit the engine you just compress the valve spring using the lever. No need to turn screw threads for each valve.
Sat Jun 27, 2020 12:04 pm
No,
but this is not too bad and you can use it to change the Bendix on Starter Motor also.
Sat Jun 27, 2020 12:37 pm
by Andrewelan
All valid points. Thanks
Sat Jun 27, 2020 4:28 pm
by steveh
I find the clamp version is more abrupt in use , there is less control -- especially on releasing tension whilst aligning the collects .
Sat Jun 27, 2020 6:15 pm
by promotor
steveh wrote:Ive got 3 types including SP, given the choice i would buy another one of these at the astonishing price of £9.
+1 for this one. Used on plenty of twincams. Easy enough to control without collets flying everywhere! Ok, it's not as quick to use as a lever type but I'm not pit crew trying to change valve springs in 5 minutes!!
Sat Jun 27, 2020 6:44 pm
by Andrewelan
Ordered one this pm. Like you I’m happy to take a few minutes per valve. On the upside they’re only 8v heads! Could be worse!
Sat Jun 27, 2020 9:34 pm
by el-saturn
as i dont really need this tool often and as i had some 20milx3 tube i easily made the tool i had to add to myy other tool selection. B UT if i wanted the best it'd bbe facom sandy
Sun Jun 28, 2020 11:54 am
by MarkDa
I had no problem with an SP lever tool when I did some work 30 years ago - there is enough reach for inlets.
