Endoscope-borescope
Help
When I plug it in now it doesn't automatically open,just makes a boing,but I have had my laptop re-jigged...can anyone tell me what it opens (no disc required)? and point me in the right direction....otherwise I may have to load the disc...
P.S Windows XP
EDIT
Just found Start,My computer,USB video device opens it,but I'm sure it was automatic before?
P.S Windows XP
EDIT
If you've been playing with your computer you will most likely have to download the disc again.
Seems the simplest solution to me anyway.
Good luck
Good luck
Beware of the Illuminati
I'm sure I didn't load the disc to start with,just plugged it in , ching, picture appeared...
john.p.clegg wrote:John
It wasn't so simple for me; had to install the software from the disc; but that does fall into line with my luck with 'puters..
Also when I use the camera I use the short cut to the software on my desk top when the camera usb is plugged in.
Some months since I last tried it though.
Its always the same, you buy a gadget & then the need for it fails to happen.
Good luck.
Or you buy the gadget and when you finally find a need it fails. ...and it's just out of warranty (not that these came with one.
I did finally use mine four months after purchase. I too had to load the program from the disc to make it work.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
If you forget how to fire it up,
Windows XP...Start....My Computer...USB Video Device...Double-Click...
No disc required
No disc required
I will yogi bear that in mind bobo
But my desk top short cut will do the same I would think but that is with the previously installed software.
Anyway, pleased to hear you're up & running again.
So is there actually any toothpaste left in that tube John
No,but my piles are a lot better....
john.p.clegg wrote:No,but my piles are a lot better....
Oh dear, that made I larf
Ooops better watch out for the inane joviality Police
