HT Lead Crimping tool - Recommendations?
Mon Sep 24, 2012 1:06 pm
by AHM
Hi All,
I am going to make my own HT leads.
Looking for a recomendation for a suitable crimping tool.
Simon
Re: HT Lead Crimping tool - Recommendations?
Mon Sep 24, 2012 1:40 pm
by elanern
Simon, here in the US I look to places like Summit Racing or Jeg's for specialized tools. For example, Summit has 4 options:
http://www.summitracing.com/search/?keyword=spark%20plug%20wire%20crimping%20tool&dds=1
- One example of a stripper/crimper
- wmr-w86500_w_s.jpg (1.29 KiB) Viewed 3545 times
Not sure about the UK, but would assume there are similar suppliers.
Good luck!
Mon Sep 24, 2012 4:19 pm
by UAB807F
Hi Simon,
Are you using the old copper cored wire or the modern silicone leads ?
I ask because I've just made up some leads for my car and didn't need any special tooling other than a pair of pliers & a soldering iron. I used copper cored wire with NGK 90deg screw-on resistor caps for the plug leads, and a standard brass terminal for the coil lead which I just soldered into place before pushing on the waterproof cover. The distributor ends are all screwed in place, or by any chance do you have a different distributor cap ?
Brian
Mon Sep 24, 2012 8:18 pm
by AHM
Brian, yes copper core. I have several sets to make for different cars. I had the screw in fittings - for one set are too big for the rubber covers on that engine.
I have all the bits just need a good crimping tool.
Elanern, looks like what I need. need a recommendation for the UK.
Simon
Wed Sep 26, 2012 3:53 pm
by plus2inbits
I use one this one from Vehicle Wiring products
http://www.vehicle-wiring-products.eu/VWP-onlinestore/htterminals/htterminals.php#crimping and it seems to work well.
I make mine using silicon lead, be careful using the copper cored and crimp on ends as I believe you'll have no suppression and may not be that popular with your neighbours!
Wed Sep 26, 2012 6:30 pm
by vernon.taylor
Salut
No suppression even with resistive spark plug caps?
I'll have to read up on this as I have a set to make up myself.
Vernon
Wed Sep 26, 2012 8:19 pm
by UAB807F
I think you'll have enough suppression with the resistive caps (the NGK ones I have are quoted as 5K) it's only if you used the plain brass crimp on ends in a rubber housing which are normally used on the modern silicone/etc leads on a copper cored wire that would make an unsuppressed lead ?
Brian
Thu Sep 27, 2012 11:10 pm
by AHM
Bumble Bee copper core leads.
And I use an inline suppressor on the coil lead, if that doesn't have the desired effect then resistive plugs.
