Nice little tool (well not so little)
PostPosted: Tue Aug 14, 2012 2:51 pm
Just found this lurking in the shed during my move/clear-out,I remember going to halfords especially for the spanner and then promptly cutting it in half and roughly taping the ends over after forcing them into a handy piece of tube...overall length 24" approx....I'll give you a couple of days to guess what for before I spill the beans...
John :wink:
Re: Nice little tool (well not so little)
PostPosted: Tue Aug 14, 2012 5:32 pm
by frearther
Bleeding clutch slave cylinder from the top?
PostPosted: Tue Aug 14, 2012 5:40 pm
by ken ob
Is it for scratching that difficult to get at itch? :lol:
PostPosted: Tue Aug 14, 2012 5:41 pm
john.p.clegg wrote:.overall length 24" approx....I'll give you a couple of days to guess what for before I spill the beans...John :wink:
...Opening tins of beans that need a spanner? (never seen one myself though) :roll:
PostPosted: Tue Aug 14, 2012 8:14 pm
by ardee_selby
john.p.clegg wrote:Just found this lurking in the shed during my move/clear-out...John :wink:
Something that has had very infrequent use, eh? Is that a clue?
For opening a can of worms? Sump plug remover to drain oil at arms length? :twisted:
Cheers - Richard :wink:
PostPosted: Tue Aug 14, 2012 10:31 pm
by reb53
Checking tightness of inner rotoflex bolts without having to get under car i.e. just removing wheel.
Ralph.
PostPosted: Tue Aug 14, 2012 10:35 pm
by AHM
Handbrake tree
Bolt inside demister intake plenum (Is there one on the inside?)
Tightening the bolt on the front cover that you can't get at
Alternator bottom bolt.
PostPosted: Wed Aug 15, 2012 12:13 am
by twincamman
Top bell housing to engine block bolts..For tightening of?...
PostPosted: Wed Aug 15, 2012 12:39 am
by Robbie693
Looks too long to be any use for tightening anything, maybe it's for holding something on one side while tightening from the other? Bit like the coil mounting bolts where you have to grip the bolt head in the engine bay while tightening the nut in the wheel arch...
Robbie
PostPosted: Wed Aug 15, 2012 7:07 am
by richardcox_lotus
Might be onto something there Robbie - to hold the bolts on the brake & clutch master cylinders ??
PostPosted: Wed Aug 15, 2012 8:27 am
by Tonyw
Richard,
I think you are correct but the car would be in Devon and you would be in Cornwall.........
Tonyw
PostPosted: Wed Aug 15, 2012 9:00 am
by elanman999
For turning the engine over when checking the tappets.
PostPosted: Wed Aug 15, 2012 12:16 pm
Ok John, how about one more clue, like the size of the spanner?
Greg Z
PostPosted: Wed Aug 15, 2012 1:37 pm
Greg
Too late,John has it,how many times have you had to put it in gear and rock the car backwards and forwards when checking the tappets,cam and ignition timing when this little spanner enables you to rock the engine or turn it over..Drops down the front of the engine between the front cover and radiator and fits the crank pulley bolt..
John :wink:
PostPosted: Wed Aug 15, 2012 2:51 pm
by elanman999
John,
Thats a very good idea, saves you cutting the back of your hand on the radiator fins.
