Great ideas, gents. Thanks.
Joh
GrUmPyBoDgEr wrote:"Where there's a will there's away"
John, don't you mean "Where there's a *mill*, there's a way?"
The machines' PO was a 65 year old machinist that's been in that trade for 35 years. I'm sure he always had access to top notch equipment, but wanted something affordable for little jobs at home. He claims to only have used it for 5 or 6 jobs over the 15+ years he owned it. Much like an Elan, it's probably suffered far more from disuse than abuse.
To your point about what the benefits of a good cleaning, I bought the unit at a very low price, partly because the electric drive motor was suspect. It would labor for 30-60 seconds, never really getting up to speed, then tripping a breaker. The PO thought it was probably the capacitor, and a relatively easy/cheap repair that I could handle. He's a really decent chap, and he promised to guarantee the motor if it was something worse than that. So, I took a flyer on it.
After pulling apart the motor, confirming the capacitor was good, having a repair shop look at it, then replacing a suspect bearing, I ran the motor independent of the lathe, and it spun right up and sounded great. I popped it back on the machine, only to get the same laboring and tripped breaker. HA! It wasn't the motor after all. What a dummy I was for following someone's assumption.
The motor drives a series of pulleys that don't use bearings of any kind, just sit on shafts with what was 20 year old glue, previously installed as grease by someone in a Chinese province as Reagan was leaving office. I removed the pulleys, did a quick wipe-down, and Voila!, it works. Just goes to show it's always good to pull back for a moment and see the forest rather than just the trees.
Why did I tell you all this? Oh yeah. I plan to disassemble enough to get it all clean and as smooth as possible. I see why that would be a good thing.
Cheers,
Dave
