Crank Trigger Wheel And Pick Up Sensor
Does anyone know where a trigger wheel and sensor pick up can be purchased for a twin cam to do away with the distributor? Also coil on plug units that will fit?
I have a fuel injection system that can cope with the ignition , so just need the above
- brian wilson
QED sells such a crank-triggered ignition system for the Twin Cam. See:
<a href='http://www.qednet.demon.co.uk/tc/ignmanage.htm' target='_blank'>http://www.qednet.demon.co.uk/tc/ignmanage.htm</a>
Their system is a nice adaptation of a DTA system. See:
<a href='http://www.dtafast.co.uk/' target='_blank'>http://www.dtafast.co.uk/</a>
Most DTA systems manage both Fuel Injection and Ignition, but the QED version employs just the ignition side of DTA's package.
The idea is very appealing. The biggest problem I see is cost. $$$$$$ when done one car at a time. Probably cost Ford next to nothing to put a similar system into a million Mondeos. Mass production!
richboyd - Third Gear
Electromotive makes crank triggered systems/components. I have an HPV-1 system on my Ferrari 308 that has been bullet proof for 4-years. I don't know if it is compatible with what you have though. See:
<a href='http://www.electromotive-inc.com/' target='_blank'>http://www.electromotive-inc.com/</a>
- bill308
i used a trigger wheel from qed with one of there crank sensor brackets though i had to modify the bracket because i am using a burton wide toothed belt drive and dry sump , lumenition 48mm throttle bodies and DTA ecu and loom and all sensors ?475 who said fuel injection was expensive
"everyone wants a piece of me and it hurts "<br>when my right leg starts shaking thats when i know i am having fun !
- steve
right place right time :blink: i also picked up a DTA ecu and loom with all sensors and jenvey throttle bodies with K series inlet manifold plus linkages and pipercross filter for an elise for ?280 the lot at stoneleigh B) <_< bargain the guy wanted ?300 DOH !!!
- steve
