Track Rod End supply source
These were the only ends I could find that had a long threaded section, unfortunately fitted to a S3 Elan so can’t say re +2. I think it’s fairly common to shorten the track rod with any replacement ends.
With new track rod ends you will need to re track the steering and check the bump steer as actual ball joint height to taper is often different.
- Craven
I think you should investigate why they don't fit your car as I have never had this problem, last year I refurbished the front suspension, track rod ends from PM everything ok.
Check the dimensions of the rack threaded ball ends and the extension rods as all sorts of things have been carried out on the racks over the years,
Hope you get sorted.
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
vxah wrote:Another thing to note with replacement tre’s is, are the ball joint centre lines the same? I noticed almost all of them sit much higher meaning the track rod will not be at the same angle it was before.
Therefore all the carefully measured rack height shimming has gone out of the window, along with it your bump steer correction?
The ball joint centre should be exactly the same ( once toe is correctly set) as the ball joint merely sits on the steering arm. The other end is fixed to the rack, so the bump steer will not be altered as the connecting rod ( be it more track rod or track rod end ) will be at the same angle.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Not sure I agree with that, any change in dimension of the replacement joint that moves the fitted height of the track rod will alter bump steer. This is because the angle of the track rod in relation to the suspension arms has changed?
Let’s say that originally at ride height the track rod was angled downward slightly, when the suspension is compressed that rod is going to scribe an arc so, if it were to move to a point where the rod is now flat then the distance between the steering rack and steering arm has now increased?
If we fit a new rod end that moves the track rod up so that at ride height the track rod is now flat, under suspension compression that rod will be angled up meaning the distance between steering rack and steering arm has decreased, I believe this will drastically change the bump steer?
- vxah
vxah wrote:Not sure I agree with that, any change in dimension of the replacement joint that moves the fitted height of the track rod will alter bump steer. This is because the angle of the track rod in relation to the suspension arms has changed?
Forgive me if I have misread the OP's issue, but I believed he was saying the threaded internal length of the track rod end was not adequate to accomodate the existing track rod when screwed in far enough to have toe correct.
I am assuming that the track rod end centre of movement to be as original, is it not?
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
My point being that I understand point A and point B to be unchanged.
The rod is the same angle and length but the point C may be altered depending on the length of the track rod and track rod ends.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
Check your rack against this for a +2
+2s130 1971
+2s130 1971
Sorry, I do understand the op’s issue. I was just saying that when “shopping around” for a replacement tre with the correct internal thread length, be aware that different ends may also have different fitted heights not obviously visible in the packet?
- vxah
I have just spoken to Amsteer in Tamworth who say whilst they don't list the correct one for my car ( +2S130)if I take over a sample they will definitely be able to either cross reference, or if push comes to shove manufacture exactly the same as what I have.
Thinking about it further I probably could alter or make GT6/Spitfire ones actually fit my car but being fussy about getting things correct that is not my way of doing things. So I intend to follow up with Amsteer and see where that leads.
Thanks all for the input.
'71 +2 S130/ 5speed Type9.
- alanr
vxah wrote:Sorry, I do understand the op’s issue. I was just saying that when “shopping around” for a replacement tre with the correct internal thread length, be aware that different ends may also have different fitted heights not obviously visible in the packet?
Ahhh! Fair enough. Quite right that would affect point 'B' and all the other conundrums.
I have to say, having recently fitted TTR supplied TREs to an S4 I didn't visually notice any difference in the ball heights and on the road the car doesn't appear to bump steer. The race car has been bump steer adjusted.
Graeme
S4 SE
S2 GTS
Caterham 420R
S4 SE
S2 GTS
Caterham 420R
