Re: Wishbone Rim Clearance
Posted: Tue May 24, 2022 3:06 pm
The washers are mentioned in the final drive section and shown fitted between the housing and wishbone.
At least one is shown in the early parts manual fitted between the w/b and housing although it could be viewed as fitted under the nut, they are also fitted on the outside.
I have always fitted them between the w/b and housing as I have seen where the bush cuts into the alloy housing if they were not fitted.
The topic has also been discussed previously on this thread.
viewtopic.php?t=30596&p=215201
