How Not To Repair A Broken Caliper Mount
Having just disassembled the rear end of my Plus 2, beginning to discover bodges that are very dubious. This is a "repair" done to the rear hub carrier caliper mounting. A plate screwed to the housing and "welded" to the flange. This will be going into the scrap bin shortly. Hopefully this was done just to get by when these cars were worthless and not an attempt to "do it right".
(I am on the lookout for a replacement in the wanted section)
- 111Robin
This was the "repair" on mine, the repair happened before me but the cracking occurred during my use. Luckily i'd sourced a new carrier as new about it, so was able to address it when i saw the cracking.
- mbell
Yes, looks like some of the ribs have been removed in your which would concern me. A new carrier is cheap compare to the damage and injuries a failure could cause
- mbell
Good catch. Hope you can replace with new. Even if you find an unbroken used one, the 50 year old castings usually have worn bearing bore fits. There are ways to repair the bores with ceramic epoxy but the machining would require making fixtures to hold the carrier for accurate boring.
Users browsing this forum: Mike133 and 28 guests
