Lotus Elan
Selecting Rod End Bearings for front suspension
PostPost by: EricB » Tue Nov 23, 2021 4:58 pm
Looking at the Aurora rod end bearings (PTFE lined) available from Pegasus Racing, for my adjustable front suspension on my '66 SE Elan that I am currently doing a ground-up restoration on, I see a choice between carbon steel rod end ones at about $20 each or the alloy steel versions at about $50 each. If I am intending to use the car for auto slaloms and track days rather than serious racing, am I OK with the carbon steel ones?
EricB
First Gear
First Gear
PostPost by: Baggy2 » Thu Nov 25, 2021 10:25 pm
I'm sure you'll get more learned responses but from memory carbon steel is relatively brittle - alloy steel is much tougher. I think I'd go for the alloy type.
Baggy
Baggy2
PostPost by: bitsobrits » Fri Nov 26, 2021 1:15 am
Just ask yourself if your life s worth the extra $120 and you'll have your answer.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: StressCraxx » Fri Nov 26, 2021 4:53 am
EricB wrote:Looking at the Aurora rod end bearings (PTFE lined) available from Pegasus Racing, for my adjustable front suspension on my '66 SE Elan that I am currently doing a ground-up restoration on, I see a choice between carbon steel rod end ones at about $20 each or the alloy steel versions at about $50 each. If I am intending to use the car for auto slaloms and track days rather than serious racing, am I OK with the carbon steel ones?
The $20 Carbon steel ones are not lined and they will wear quickly. They are not made to the tolerances or precision of the alloy version. In addition, either version will have the bearing exposed to the elements. Not ideal. So, the solution are these:
https://www.aircraftspruce.com/catalog/ ... ealsit.php
In addition, since the bearings are in single shear, one should use a capture washer under the head of the fixing bolt in case of joint bearing failure.
https://www.pegasusautoracing.com/docum ... =TECH00014
For background on the above, since you are making an engineering change, read "Prepare to Win by Carroll Smith, http://www.carrollsmith.com/books/index.html
StressCraxx
