A frame bush removal
I used a hefty bolt (coarse thread) through sockets.. my first attempt with a vice resulted in a broken vice (it was an old vice, with unknown history - but went with a bang)... this was some years ago.. A mix of soaking, cutting and pressing should do the trick
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
Wow, though it is pretty obvious no-one had made it clear that you put the blade of the hacksaw through the hole in the centre of the bush and cut outwards. I hate to think of what might happen if you misinterpreted the advice above and sawed through the retaining socket on the chassis/subframe or A-Frame.
Meanwhile here is a link to a topic where this matter was discussed in detail and which shows photos of a tool that I made back when I had a lathe.
viewtopic.php?t=28632&p=189898
But these are for the bushes on the frame, I think it would be too big for the outers of the a-frames.
Whatever bushes are being removed OR replaced, heating the offending article makes a big difference. I am talking about the part that the bush is fitted in. You might think that the heat will travel through the retaining part to the bush, which it does, therefore making no difference, but trust me, it is like chalk and cheese. Even more so when fitting the new bushes, so much easier with heat. You would not dream of removing / fitting bearings in an alluminium casing without heat, why not the same with steel.
Leslie
Leslie
- 512BB
100% agree with the previous poster (Leslie). I made a tool with threaded bar and sockets and it took a huge force without the bush moving, to the point I was concerned something would break. Heated with a standard blowtorch and as soon as the correct temperature was reached out slid the bush with only mild resistance. Hard to say how hot you need to get it, and I guess it will depend on how long its been in there under what conditions etc. But the difference a few degrees make is like night and day.
Best of luck
Best of luck
- steve.thomas
