Rear standard spring caps
PostPost by: Hawksfield » Thu Sep 02, 2021 1:32 pm
What's the solution to replacement rear standard spring cap replacement.
I believe they are Anglia and unobtainable.
Any help appreciated
+2s130 1971
PostPost by: jono » Thu Sep 02, 2021 1:50 pm
I sold a good pair last year so second hand will be the way forward.
There ought to be a ready supply from those who have gone the narrow spring route - I would contact Spyder and see if they have some left over from narrow spring conversions
PostPost by: englishmaninwales » Thu Sep 02, 2021 3:58 pm
Yes, keep a watch on eBay as they come up from time to time. Also if the ‘D’ in the hole for the damper rod is rounded they can be repaired.
1966 Elan S3 Coupe
1994 Caterham 7
PostPost by: RichardHawkins » Thu Sep 02, 2021 6:11 pm
John,
I have bought two of these from Spyder many years ago. They are a fabrication rather than being pressed in one piece, but seem to be OK.
Hope this helps,
Richard Hawkins
RichardHawkins
PostPost by: mbell » Thu Sep 02, 2021 7:38 pm
TTR also sells replacements:
https://www.tonythompsonracing.co.uk/pa ... rear-elan/
The narrow ones are fabricated not pressed and guess these might also be.
PostPost by: fotsyr » Fri Sep 03, 2021 11:35 am
I have a pr of good used ones available. Located in the USA.
fotsyr
First Gear
First Gear
PostPost by: nmauduit » Fri Sep 03, 2021 11:55 am
mbell wrote:TTR also sells replacements:
weight 2kg each... I would have thought they'd be a competition version ;)
S4SE 36/8198
PostPost by: Hawksfield » Fri Sep 03, 2021 3:37 pm
Hi All
Thanks for the info. The TTR spring seats are for lower spring seats not the same as the ford spring cap,
Which suit the original lotus springs
+2s130 1971
PostPost by: mbell » Fri Sep 03, 2021 6:13 pm
nmauduit wrote:weight 2kg each... I would have thought they'd be a competition version ;)
I suspect they are reasonably thick steel but I somehow don't believe 2Kg is correct, even for a pair. Maybe 1KG for a pair.
Hawksfield wrote:The TTR spring seats are for lower spring seats not the same as the ford spring cap,
Yes good point, apologies missed that when scanning through the options. (Useful to know if I i don't like the narrow spring setup I am currently installing.)
PostPost by: Bigbaldybloke » Tue Sep 21, 2021 9:29 pm
Might have a pair under the bench somewhere if you are still looking as I’ve changed to the narrow springs.
PostPost by: Hawksfield » Fri Sep 24, 2021 9:56 am
Thanks for that, I was thinking for the future and not desperate so I knew what was out there I think at the moment my solution will be to weld and re cut the "D" hole.
Thanks again I will keep yours in mind.
+2s130 1971
