Loose outer lower a-arm bolt
While doing a rebuild on the front brakes (see "What did you do to your Lotus today"), I noticed that the outer bolt on the lower a-arms was loose. With the front end up, wheel off, if I put a load on the hub, the hub would drop a bit before the a-arm did - maybe an 1/8 - 3/16 inch or so.
I just tightened up the outer bolt a bit - was that the right fix, or do I have a bigger problem?
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle - Third Gear
steve lyle wrote:While doing a rebuild on the front brakes (see "What did you do to your Lotus today"), I noticed that the outer bolt on the lower a-arms was loose. With the front end up, wheel off, if I put a load on the hub, the hub would drop a bit before the a-arm did - maybe an 1/8 - 3/16 inch or so.
Sounds like you have worn bushes in the trunnion or oval holes where the trunnion bolt goes through the arms. Both a common.
rgh0 wrote:Sounds like you have worn bushes in the trunnion or oval holes where the trunnion bolt goes through the arms. Both a common.
If the latter, arms need replacing? I.e., tightening up the bolt was just a temporary fix?
Steve Lyle
2007 BMW 335i Coupe
2007 BMW 335i Coupe
steve lyle wrote:rgh0 wrote:Sounds like you have worn bushes in the trunnion or oval holes where the trunnion bolt goes through the arms. Both a common.
Or weld a washer in place....
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Users browsing this forum: TWebb and 23 guests
