Rear suspension service advice
These lock-down days are great! I have so many jobs that await delivery from ebay of various bits 'n bobs that I just roll onto the next one! The car is now in a serious pile of pieces!
Today, rear suspension. A few surprises - one side has a brand new hub and both brake calipers are new. Then I notice a huge gash on the inside of a wheel, so much of a one that I am surprised it still holds air. Obviously something big happened, and I need a new wheel. But the upside is that the brakes are new and the handbrake easily passes MoT.
I seek some advice please:
1. There are what seems to be factory pressed panels under the wishbones and, on one side, a cover affair over the discs. Did Lotus go to this trouble? I shall ditch them as they are unsightly and get in the way - unless someone tells me there is any technical merit that has escaped me...
2. Shocks look original! So maybe a birthday present of new ones - Paul Matty offers a choice: Protech, Koni (£300??), Gaz or Spax. Are there any suggestions for comfortable road use please?
3. I may as well service the bushes and bearings (althyough I expect one is new). Again, any suggestions from experience - off the shelf ones a la Paul Matty, or Superflex?
4. I have a Spyder chassis - do I assume that it uses the original Lotus wishbones and that I do not have to specify anything special regarding bushes and bearings?
5. Were springs ever a problem? After 47 years, do I continue with them or replace? The car sits pretty square.
One side has a newish doughnut and the other is reliant on two of the three bolts! I do not know if this is a contention, but are the drive shaft replacement really necessary for comfortable road use? Am I going to be ok with new Rotaflexes?
Again thanks for any snippets
Hal
Hal
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
HCA - Coveted Fifth Gear
Hi Hal,
If you are going to buy new shock absorbers then you have an opportunity to buy the shorter limited droop ones, in case you decide to fit CV shafts in the future. They will not make any difference to the ride or height of your car, so nothing is lost. Kelvedon stock them I believe.
Just a thought,
Eric in Burnley
1967 S3SE DHC
Just a thought,
Eric in Burnley
1967 S3SE DHC
- ericbushby
Is this a Plus2 or an Elan (avoids the word baby )?
Later Plus 2s - S130s came with rear wishbone shields which acted as tambourines with gravel.
Plus 2s don't need droop limiters to protect CV shaft joints from lockup.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Apologies - it is a 1973 S130.
I note on Paul Matty's website, the Konis are specifically 'limited drop'. Unless anyone tells me that the Rotoflex is a killer, then I do not think I will need the driveshaft upgrade...
Jon - tell me more about the Konis - you say lots of life left in them, how so? I could be interested. What about fronts as well - do you have these too?
Anyway - another job finished before it has started - just called Paul Matty.'' Regrettably had to shut until April 7''
Thanks Phil for confirming the futility of the shields!
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
Ah, Plus 2, droop limiter not necessary.
Eric in Burnley
Eric in Burnley
- ericbushby
I can recommend http://dampertech.co.uk/ I bought my GAZ shocks from them and their price was the best and the service very good.
Rear shock part number is GAI 1063 and front is GP6 2131 (height adjustable)
I am very happy with the shocks after three years of very hard use.
'65 S2 4844
- Davidb
Q1 - There were an assortment of pressed tin panel around the rear disks and suspension. Supposed to keep spray and road dirt off the area but most owners removed them....
Q2 - If the shocks are working OK and not leaking then there is no real reason to replace.
Q3 Bushes should be standard. Sue Millar Poly bushes (Road spec) are good and easy to fit. I struggled to fit new metalstic bushes to my rear suspension 'A' arms while polybushes went in really easily.
Q4 Spyder chassis should use all standard bushes
Q5 Standard springs should be fine after all Chapman knew a bit about suspension design! Workshop manual gives rear spring length as (free) 16.0 in (40.6 cm), front (free) 14.9 in (36.04 cm)
HTHs
Matt
HTHs
Matt
Visit me on matthewvale.com
Matt Elan - Fourth Gear
Thanks Matt,
This is often the case that poly bushes are easier to install. I might follow this road. Thanks too for the spring measurements. I will note them for when I strip it all down.
Do you have any views on Rotaflex drive couples?
Hal Adams
Evora S
Elan +2
Evora S
Elan +2
My +2 S130 still has the underside wishbone protection panels and also the protection panels over the top of the rear suspension. Most +2's have at some point had them removed and I guess how much they protect the rear suspension from the weather and gravel rash is debateable.
They are also a bit of a pain to remove and refit every time you work on the rear suspension but personally I think they are a nice touch and will be keeping mine for originalities sake.
'71 +2 S130/ 5speed Type9.
- alanr
My understanding was that they were fitted to reduce excessive wear being experienced on the rear disks on the Plus 2 due to dust and dirt being thrown up onto the disk. When I got my Plus 2 back in the Early 80's there was a very rusted set in the box of spares that came with the car. My car came to Australia after spending its first 5 years in the UK so they did not last long.
I never refitted then and threw them out long ago and I have not experienced excessive rear disk wear so it appears they are not that critical
My car had them until last year when I refurbed the suspension. They're currently gathering dust in a corner of the garage. I'm gonna keep them in a box in the attic because so.eday some originality-purist will want a set at any price!
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
