How I jack up & support my Elan
I've made a video (as requested) to show how I jack up and support my Elan. May be of general interest:
https://youtu.be/E4YUz55ELEw
Paul
Paul
66 Elan S2
- PaulH
Thanks for this Paul, very informative.
I perform similar manoeuvres- they are just a pain to get in the air in a quick and simple fashion.
'72 Sprint
'72 Sprint
- richardcox_lotus
For a reinforced 26R stye frame I made a pi shaped piece of wood to fit around the exhaust pipe between the rear rose joints. It's a similar idea to Paul's but a 2" pipe and the triangular reinforcing on the bottom of the chassis makes it a challenge. Sloping the legs of the pi with 45 deg bevels makes it possible to get around the pipe and rest on the reinforcing nicely.
Paul's idea for the individual rear corners works a piece.
- baileyman
gjz30075 wrote:Another great video Paul. Thanks! One dimension I didnt' see was where the slot is in relation
to the edges of the board. Can you provide that?
I've put the dimensions of the wooden jacking support block in the attached file.
Paul
66 Elan S2
- PaulH
I just put a Plank under the Sill between front and back wheel and jack it up.
Many times you are only working on one side at a time.
If you need to lift both sides at the same time it's different.
- alan.barker
PaulH wrote:gjz30075 wrote:Another great video Paul. Thanks! One dimension I didnt' see was where the slot is in relation
Paul
Thanks for that Paul, should the 2nd dimension on the left be 125mm?
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Users browsing this forum: ericbushby, lotusfan and 26 guests
