Handbrake assembly through bulkhead.
PostPost by: 661 » Wed Feb 05, 2020 10:17 pm
Please remind me , I've forgotten.
This is going through a new shell and I can't recall which size hole I need.
I believe 'PART A' rests on the bulkhead from the inside and the hole is big enough for the whole cable to go through, ie 11.03mm?
The 9.97mm bit sits within PART A up to the point where the cable sheath starts.
Is there a grommet?
IMG_0833.jpg and
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: oldelanman » Thu Feb 06, 2020 11:05 am
Yes there is a substantial grommet in the bulkhead and your part A should be a snug fit through it, that provides the mount for the lower end of the ratchet tube. Can't help with the hole size but it's going to be your 13.6mm dimension plus the grommet thickness. Both S J Sportscars and Paul Matty supply it as part of an engine bay set, not 100% certain but I believe it's the one arrowed below ... the heater hose ones are next to it for size comparison.
Bulkhead grommets.jpg and
S4 DHC
PostPost by: pharriso » Thu Feb 06, 2020 12:02 pm
My list of Grommet sizes has the Hand Brake Cable grommet at 9/16" x 3/4" x 1" ID xHole xOD
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: oldelanman » Thu Feb 06, 2020 12:40 pm
pharriso wrote:My list of Grommet sizes has the Hand Brake Cable grommet at 9/16" x 3/4" x 1" ID xHole xOD
I reckon that's about right.
Just found an old one (never throw anything away :roll:)
IMG_20200206_113111.jpg and
IMG_20200206_112732.jpg and
S4 DHC
PostPost by: 661 » Thu Feb 06, 2020 6:15 pm
Thank you to you both
Graeme
S4 SE
S2 GTS
Caterham 420R
Users browsing this forum: No registered users and 46 guests
