Elan45 wrote:On my Elans, the clevis end of the rod from the swivel was held to the lever arm of the caliper with a 10-32 screw and nut. Then push the screw out of the clevis and the parking brake is released.
I noticed that your rear struts look like +2 struts with the extra mount for the the transition from steel tube to hose. I thought your Elan was a S2?
You will want an internal pipe wrench to remove the almost certainly very stuck pistons. I can't remember whether the size is 3/4 or 1 inch. I bought a set of 4 sizes off ebay.
Roger
Good morning Roger, thanks for the response. My Elan is a ?69 DHC so if those are +2 struts the car has been fiddled with.
Any issues or advantages in running the +2 struts (if that is what they turn out to be, need to get researching).
Thanks for the eyes on it!
