Seems like a weird amount of oil
Very odd indeed. Should be dry.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Nobody's said it yet, so I guess I will: don't question it, and look on the positive side: it's preventing rust! Those steering column U-joints need all the rust prevention they can get... although the oil is probably wasting the rubber. Quick story: I had to upgrade mine from the rubber bush type to the real U-joint type last winter and I ended up cutting the pinch bolts and the old joint itself into about 7 different pieces with a die grinder to get it off. What a disaster.
I also thought I lined up the column correctly with the rack when I put it the new joint back on (there was no alignment flat on the rack like there was on the column so I had to make an educated guess) but alas I was off by one spline... so now "straight ahead" is actually some small number of degrees (6?) off of center on the steering wheel
1965 S2 26/4623
- benymazz
I fitted a U-joint just today and had the opposite experience: the old flex-joint came off fairly easily but the new U-joint required lots of toil and effort and hammering. It's probably never going to be able to come off now, so I hope I got the alignment right! I did actually make a punch-mark on the rack housing and on the column to help with alignment so with any luck that paid off.
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
I have seen three different Triumph steering UJs. The first had a rubber/fabric disc sandwiched in the middle, the second a metal disc with rubber inserts (that I think you have under the grease), the third a 'proper' hook type universal joint. I would imagine the rubber inserts are well on their way to being perished by now and your joint (and steering) may benefit from a replacement.
I did come across this:
https://www.ebay.co.uk/itm/TRIUMPH-STEERING-SHAFT-UNIVERSAL-JOINT-UPGRADE-SPITFIRE-GT6-TR6-TR5-TR4A-TR250-/162823606997
..which looks a thing of beauty. No idea if it is mechanically sound, but it looks great.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
Looks to me like the DPO had just finished filling his trunnions with EP 90 and figured to get rid of the rest of his devil's mix on the steering column. Overall, I agree that there's probably sufficient rubber down there that this kind of lubrication was a very bad idea safety-wise.
- denicholls2
Just took another look at your photo and you definitely have the original rubber/fabric doughnut down there. Covered with moly grease or whatever that gunk is, it should not take it long to rot to the point where it separates easily when stressed. Say, back up out of a tight parking space, pull forward, drive off, and hit that hard left-hander at speed...
Perhaps the DPO felt he was adding a preservative, but I wouldn't bet my life or my passenger's on that being the case.
- denicholls2
