26R 5 peg wheels
Wed Aug 28, 2019 2:27 pm
by zeca
Hello,
I bought a used set of 26R 5 peg wheels and the 26R spinners. When installing the wheels in the car, i realised that the spinner don?t go at the end of the thread of the Hub.
This set is from Kelvedon, They told me to remove 5 or 10mm inside the wheel....
Any help on this?
Best Regards
Re: 26R 5 peg wheels
Wed Aug 28, 2019 2:41 pm
by zeca
dimension of the wheel
Thu Aug 29, 2019 5:00 am
by jabingb
I don't have one of my wheels off the car but even 5-10mm doesn't appear to be enough? And then there's the issue of does the wheel have enough meat to safely allow it. Is it a matter of hub/spindles not being long enough? I take it this is not a true 26R but some adaptation? Here are a couple pixs of my Series 2 front and rear, the latter with the protruding spindle/hub tube, albeit rusty.
Tue Sep 03, 2019 2:26 pm
by zeca
Does anyone have a set of 26R 5 peg that can tell me the depth of the wheel? Mine is about 35mm as image above.
thanks
Thu Jan 30, 2020 4:54 am
by Dale Harvey
zeca wrote:Does anyone have a set of 26R 5 peg that can tell me the depth of the wheel? Mine is about 35mm as image above.
thanks
Yes, I have a set of brand new ones and they are the same. I haven't decided what to do about it yet but I am certainly not happy with only half the amount thread being used. I would not be happy machining the mounting face either as that will make the offset worse.
Dale.
Sat May 23, 2020 6:08 am
by Dale Harvey
Has anyone had a go at solving this problem of not enough threads on the hub?
Sat May 23, 2020 3:38 pm
by msd1107
RE: Number of threads.
Carroll Shelby's book may address that question.
There is a professional book on fasteners, but, at $300+ probably not many people have it.
I seem to remember that something like 4 threads engaged provides sufficient strength.
Perhaps Rohan can give us guidance.
Cheers,
David
1968 36/7988
Sat May 23, 2020 3:53 pm
I think you mean Carroll Smith.
Sun May 24, 2020 1:36 am
by bitsobrits
Carrol Smiths advice on threaded fasteners (from memory, so beware) was 1.5 diameters for thread engagement, with a minimum of 1 diameter. I do not recall if he provided any advice on knock off nuts, which may well be different.
In any case, I would not feel comfortable with only 4 threads engaged on a heavily loaded wheel nut. I would be looking for a least one thread past the end of the nut, or a thread engagement length equal to at least the diameter of the threads.
Sun May 24, 2020 8:29 am
by nmauduit
bitsobrits wrote:Carrol Smiths advice on threaded fasteners (from memory, so beware) was 1.5 diameters for thread engagement, with a minimum of 1 diameter. I do not recall if he provided any advice on knock off nuts, which may well be different.
The above setup appears to have a problem (hub too short for this specific application?) and I also would not drive at speed on 4 alloy threads, but if I may, "a thread engagement length equal to at least the diameter of the threads" is clearly impossible with the stock KO nuts, that have a threaded depth about half of their diameter (and are engaged on steel wheel 7 to 8 threads I would say)...
Mon May 25, 2020 11:15 am
by vstibbard
I agree, Gordon who bought my S2 put Kelsport 26R 5 peg wheels on and it had only a few threads holding it on, I suggested best not to drive it.
For my mind a poorly engineered solution and an accident waiting to happen
V
Mon May 25, 2020 11:23 pm
by Dale Harvey
I think all agree that there's not enough threads on the hubs for this setup. What I need is a good and safe way of extending the threaded section on the hubs.
Tue May 26, 2020 1:20 am
by 1owner69Elan
Tue May 26, 2020 1:53 am
by elancoupe
Dale Harvey wrote:I think all agree that there's not enough threads on the hubs for this setup. What I need is a good and safe way of extending the threaded section on the hubs.
I have had these Kelvedon wheels on my car 21 years now with no issues. My TTR spinners have 11 total threads, with between 8 and 9 engaged. Given that Cobra Halibrands only have about 9 total threads, I don’t think it’s a problem.
My wheels certainly do not have as many exposed threads like the photo at the top of this thread. Perhaps spinner differences?
Tue May 26, 2020 2:11 am
by 1owner69Elan
TTR replica 26R wheels and spinners. Full engagement of threads front and back. Pretty much the same as "jabingb" 's true 26R.
Front:
Back:
