Rear Dampers
Posted: Wed Nov 07, 2018 7:49 pm
I've been told by a normally unimpeachable source that the dampers for the Elan and the +2
are exactly the same. As in interchangeable.
Is this correct?
I'm still gathering the bits to replace my entire (and virtually new) Spyder double wishbone
rear suspenders with original struts. The rubber helper / bump stop springs (on the S/H struts I bought)
have collapsed so that the alloy spacer was inside. Is this a normal occurrence?
I'll shortly have a full Spyder rear end for sale if you are building a Zetec!
Is this correct?
