How many turns does a trunnion need to be screwed on?
• Page 3 of 3 • 1, 2, 3
Seal pictures
- Bigbaldybloke
The Veg wrote:So back to the orignal topic, does this look OK? Both seals in the picture are new and both are pointing the same direction. This is as far as the trunnion would go and still turn 180 deg., but the seal does introduce a bit of resistance despite the amount of grease to which it has been exposed.
The one on the finger is orientated correctly.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Well just to show you I?m making progress and the suspension is reassembled with the trunnions screwed on approx 15 turns. New machined down hubs installed with new bearings, new brake discs, calipers and pads. The lock rings arrived back today so after bleeding the brakes the Minilte wheel was duly fitted and the spinner tightened and secured the wheel without bottoming out on the thread before the wheel was tight. Success. Incidentally one trunnion seal was really perished and cracked and split and just broke up if you flexed it, the other was good as new but both were the same age, approx 20 years old.
- Bigbaldybloke
Just to prove that I'm not kidding. Note that in this video the parts are dry; if properly lubed it would go on a little farther and cause even more deformation.
https://youtu.be/uxFbrJ-kzJc
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
