Sizes of brake line components?
I'm soon going to be making a couple of new brake lines for the Plus 2, going straight from the master (.7" Girling dual) to the lines to the front and rear, eliminating the servos. What size fittings will I need to use, and is each end the same size or different size?
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
I think are the same and you only need to be careful with the pipes that screw into the front calipers( some imperial thread, some metric).
Be sure to put the correct flare or double flare on the ends. I only use "Kunifer" tube for brake lines, no rust problems after
- alan.barker
The Veg wrote:going straight from the master (.7" Girling dual) to the lines to the front and rear, eliminating the servos.
Alan and Phil are both correct. It is later +2 versions that have M10 fittings in the front calipers. You won't necessarily be touching the front calipers to make this modification. Keep the servos handy, stopping a +2 without the 3:1 boost ratio servos requires an almighty shove on the brake pedal, even with a 5/8" bore master cylinder. I put my servos back in after a similar experiment. I become worried about how much the fiberglass at the base of the pedal box deformed when stopping without the servos.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
When I replaced the front and rear brake lines on my August 72 Plus2, the lines from the balance block had two different sized fittings. The fronts had 7/16", while the rear had 3/8". The DPO had removed the servos and dumped them at some point, and the 1" original master needed both feet on the pedal to stop the car. I replaced the original master with an 11/16" Datsun dual master, which works without the servos and it provides a pedal feel similar to my S2.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
I found it difficult to find a .7"/11/16" dual master cylinder, as most dual masters are associated with a servo/vacuum assist, and their bores are much larger. Being familiar with the Datsun 1200/Sunny, I knew its diameter was 11/16", and it was used without a power assist. It does require some modification, as the bottom feed will hit the body on a Plus2. The bottom bosses were shortened and capped off with a shortened 16mm bolt and a copper washer, and the new feeds were taken from the bleed nipple locations on the side of the cylinder.
To direct the lines towards the balance block, AN-3 to 1/8" pipe 90's were used at the master. The 3/8 and 7/16 fittings from the old lines were re-used at the block.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
26-4889
50-0315N
1964 Sabra GT
- prezoom
I found a GIrling one, externally identical to the 7/8" unit that came with the car. Only hitch is that it was missing the pushrod. I have yet to find a pushrod for it, so I may just file down the disc on the one from the 7/8" unit.
2012 BMW R1200GS
2012 BMW R1200GS
You will need to check the length also of the rod.
- alan.barker
prezoom wrote:When I replaced the front and rear brake lines on my August 72 Plus2, the lines from the balance block had two different sized fittings. The fronts had 7/16", while the rear had 3/8". The DPO had removed the servos and dumped them at some point, and the 1" original master needed both feet on the pedal to stop the car. I replaced the original master with an 11/16" Datsun dual master, which works without the servos and it provides a pedal feel similar to my S2.
You're just the man I need to talk to I have a Datsun dual M/C. What are the bleed nipple/zerks on the side ffor? Can I blank them off? Are the fittings 3/8th UNF?
Many thanks in advance
Mazzini - Coveted Fifth Gear
gav wrote:If you are planning to omit the servo wouldn’t you replace the master with a 0.625 (ie go down one full size) to prevent having to stand on the brakes pedal each time you want to stop?
Gavin
That would help with pedal loads but would increase the travel and you would also have to check that you have enough fluid displacement to fill the calipers and don't run out of travel.
- mikealdren
