Replace Steering 'flexible joint' on early +2
Posted: Sun Jul 02, 2017 8:49 pm
Hi Everyone,
I am trying to replace the steering joint and am struggling. My car is 50/0009 so I assume I have a solid one piece steering column. The manual says to undo the pinch bolt on the joint then pull the steering wheel up, however even with quite a bit of force I only get a few mils of movement which isn't enough to pull the column out of the joint. I am afraid of being too heavy handed and damaging something. I took apart the binnacle to see if there is any obstruction 'up top' but nothing seems to be limiting the movement. Can someone please point me in the right direction? Do I actually need to remove the pinch bolt from the joint, at the moment it is just slackened off.
Here's a pic or two of the column where the outer ends, just in case I actually have a collapsible column without realizing
Cheers,
Bob.
