Front Hub Rear Bearing Question
Posted: Fri Jan 06, 2017 10:42 am
Hi Just a quick question , as I can't see the answer in the manual.
The front outer wheel bearing just pops out when the nut is removed , however the rear bearing is held in by a circular cover. should this just pop out ?
I wanted to remove both bearings , inspect and re-grease.
Thanks Steve
Thanks Steve
